[Bio] / FigKernelPackages / FIGMODELObject.pm Repository:
Log of /FigKernelPackages/FIGMODELObject.pm
Revision 1.5
Tue Jan 4 21:22:08 2011 UTC (9 years, 4 months ago) by chenry
CVS Tags: HEAD
Changes since 1.4: +0 -0 lines
FILE REMOVED
Moved FIGMODELObject.pm to ModelSEED/ModelSEEDObject/ and fixed bugs in other model modules.
Wed Apr 21 22:18:05 2010 UTC (10 years, 1 month ago) by chenry
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.3: +18 -0 lines
Implemented new function to change the name of a date header.
Wed Apr 29 19:52:47 2009 UTC (11 years ago) by chenry
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118
Changes since 1.2: +19 -17 lines
Wed Mar 4 00:07:47 2009 UTC (11 years, 2 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.1: +348 -349 lines
Minor changes in new-lines and tabs.
Tue Mar 3 21:53:00 2009 UTC (11 years, 2 months ago) by chenry
