[Bio] / FigKernelPackages / FIGM.pm Repository:
Log of /FigKernelPackages/FIGM.pm
Thu Jul 29 19:17:42 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, myrast_33, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.17: +29 -0 lines
Diff to previous 1.17
Add FIGV and FIGM function_of_bulk
Thu Aug 27 20:48:41 2009 UTC (10 years, 6 months ago) by olson
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.16: +127 -56 lines
Diff to previous 1.16
Support for Seedviewer Subsystems.pm speedups.
Mon Jun 22 15:06:56 2009 UTC (10 years, 8 months ago) by paczian
CVS Tags: rast_rel_2009_07_09
added preference option for annotators to display aux roles on the annotation page
Wed May 27 17:00:35 2009 UTC (10 years, 9 months ago) by paczian
Changes since 1.14: +22 -0 lines
added FIGfam support for RAST orgs
fixed deleted_fids hash
Thu May 7 10:15:13 2009 UTC (10 years, 9 months ago) by paczian
CVS Tags: rast_rel_2009_05_18
fixed call to seqs_with_role to match FIG.pm invocation
Mon Apr 20 14:55:43 2009 UTC (10 years, 10 months ago) by paczian
Changes since 1.12: +12 -0 lines
added method genome_info
Thu Mar 26 09:53:35 2009 UTC (10 years, 11 months ago) by dejongh
CVS Tags: rast_rel_2009_03_26
Changes since 1.11: +18 -17 lines
Moved variant code loading outside of for loop to speed up processing of multiple genomes in a FIGM
Tue Mar 17 14:32:47 2009 UTC (10 years, 11 months ago) by dejongh
Changes since 1.10: +7 -0 lines
Added shell for seqs_with_role
Thu Feb 5 16:21:55 2009 UTC (11 years ago) by paczian
Changes since 1.9: +42 -1 lines
added function subsystems_for_pegs_complete
Tue Jan 20 11:12:53 2009 UTC (11 years, 1 month ago) by paczian
CVS Tags: rast_rel_2009_02_05
Changes since 1.8: +36 -0 lines
added the function "coupled_to_batch"
Thu Dec 4 14:04:17 2008 UTC (11 years, 2 months ago) by paczian
CVS Tags: rast_rel_2008_12_18
Changes since 1.7: +14 -0 lines
added subsystems_for_peg_complete
added protein_subsystem_to_roles
Thu Nov 20 15:49:17 2008 UTC (11 years, 3 months ago) by paczian
CVS Tags: rast_rel_2008_11_24
Changes since 1.6: +15 -0 lines
added add_feature and delete_feature
Thu Nov 13 21:49:55 2008 UTC (11 years, 3 months ago) by dejongh
Changes since 1.5: +3 -2 lines
fix scenario_directory to work for All
Wed Nov 12 18:24:13 2008 UTC (11 years, 3 months ago) by dejongh
Changes since 1.4: +6 -7 lines
switch to scenario_directory
Tue Nov 11 13:41:27 2008 UTC (11 years, 3 months ago) by paczian
Changes since 1.3: +104 -0 lines
updated for use with FIGM
Thu Nov 6 11:05:12 2008 UTC (11 years, 3 months ago) by paczian
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2
Changes since 1.2: +29 -4 lines
added support for FIGM
Thu Oct 2 21:48:41 2008 UTC (11 years, 4 months ago) by olson
CVS Tags: rast_rel_2008_10_09, rast_rel_2008_10_29
Changes since 1.1: +47 -2 lines
FIGM/FIGV changes for sims between RAST orgs.
Thu Jun 26 21:11:11 2008 UTC (11 years, 8 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_release_2008_09_29
Add annotation support to FIGV. Add FIGM.
