[Bio] / FigKernelPackages / FIGGenDB.pm Repository:
Log of /FigKernelPackages/FIGGenDB.pm
Mon Dec 5 19:06:30 2005 UTC (14 years, 5 months ago) by olson
Added license words.
Thu Jul 14 15:53:54 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.4: +3 -0 lines
Fixed lost username in protein.cgi and removed Bound/Find uncalled gene from FIGGenDB.pm
Thu Nov 11 04:22:48 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.3: +25 -15 lines
GenDB changes.
Thu Oct 28 16:35:54 2004 UTC (15 years, 7 months ago) by olson
Fix in linkClusterGenDB too.
Thu Oct 28 16:33:48 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.1: +12 -5 lines
Tweak to make the links work right in a seed install.
Fri Oct 22 17:05:18 2004 UTC (15 years, 7 months ago) by heiko
gendb params and methods
