[Bio] / FigKernelPackages / FIG2.py Repository:
Log of /FigKernelPackages/FIG2.py
Added license words.
Tue Jun 1 02:36:32 2004 UTC (15 years, 8 months ago) by olson
First cut at python FIG module that uses the CallPerl direct call interface.
