[Bio] / FigKernelPackages / FIG.py Repository:
Log of /FigKernelPackages/FIG.py
Changes since 1.12: +17 -0 lines
Diff to previous 1.12 , to selected 1.10
Added license words.
Fri Oct 21 14:50:26 2005 UTC (14 years, 1 month ago) by overbeek
CVS Tags: caBIG-00-00-00
Changes since 1.11: +27 -1 lines
Diff to previous 1.11 , to selected 1.10
Make cgi_url return a proper relative path if possible.
Fri Apr 15 19:55:44 2005 UTC (14 years, 8 months ago) by olson
CVS Tags: Root-bobdev_news, caBIG-dataload-0, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
Changes since 1.10: +54 -0 lines
Added helper stuff for new clearing house interface.
Revision 1.10 - (view) (download) (as text) (annotate) - [selected]
Tue May 4 16:37:53 2004 UTC (15 years, 7 months ago) by olson
Make it look at the right xmlrpc server path.
Tue May 4 16:27:45 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.8: +81 -0 lines
Diff to previous 1.8 , to selected 1.10
add xmlrpc support for accessing FIG.pm methods
Wed Apr 28 21:59:32 2004 UTC (15 years, 7 months ago) by olson
Diff to previous 1.7 , to selected 1.10
Clearinghouse publishing stuff
Fri Mar 26 21:38:38 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.6: +12 -0 lines
Diff to previous 1.6 , to selected 1.10
Make get_local_hostname check for a FIGdisk/config/hostname file and use
that as the local hostname if present.
Mon Mar 15 23:14:11 2004 UTC (15 years, 9 months ago) by olson
Diff to previous 1.5 , to selected 1.10
minor change.
Mon Mar 15 23:06:47 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.4: +30 -0 lines
Diff to previous 1.4 , to selected 1.10
Add get_seed_id()
Mon Feb 23 22:58:03 2004 UTC (15 years, 9 months ago) by olson
Diff to previous 1.3 , to selected 1.10
Fix the hostname.local problem again; apparently sometimes you
get "hostname.local" and sometimes you get "hostname.local.".
Mon Feb 23 17:18:19 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.2: +16 -5 lines
Diff to previous 1.2 , to selected 1.10
Add a check for hostname.local.
Thu Feb 12 16:04:21 2004 UTC (15 years, 10 months ago) by olson
Changes since 1.1: +3 -4 lines
Diff to previous 1.1 , to selected 1.10
mac fixes, remove debugging
Thu Feb 12 16:00:31 2004 UTC (15 years, 10 months ago) by olson
Diff to selected 1.10
python version of some FIG.pm stuff
