[Bio] / FigKernelPackages / FIG.pm Repository:
Log of /FigKernelPackages/FIG.pm
Links to caBIG-13Feb06-00: (view) (download) (as text) (annotate)
Revision 1.436 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Feb 5 01:08:16 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.435: +47 -0 lines
Diff to previous 1.435
RAE: Swtiched to using SQL Count for the number of contigs
Revision 1.435 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Feb 3 18:42:27 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.434: +3 -1 lines
Diff to previous 1.434
$/ fixes
Revision 1.434 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 31 04:09:13 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.433: +32 -51 lines
Diff to previous 1.433
fix of clustering
Revision 1.433 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 30 19:36:04 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.432: +6 -2 lines
Diff to previous 1.432
use is_genome checks for subsystems?
Revision 1.432 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jan 29 19:48:31 2006 UTC (13 years, 10 months ago) by efrank
Changes since 1.431: +10 -6 lines
Diff to previous 1.431
fixes for controlled vocab from NCI demo.  fixes to accomodate RAE's
changes in key_info.  commit independent of other pkgs.
Revision 1.431 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Jan 28 04:23:47 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.430: +29 -1 lines
Diff to previous 1.430
RAE: Updating POM -- pieces of metabolism
Revision 1.430 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 25 18:57:05 2006 UTC (13 years, 10 months ago) by olson
Changes since 1.429: +29 -9 lines
Diff to previous 1.429
Add more sim compute stuff.
Revision 1.429 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 23 19:20:54 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.428: +131 -4 lines
Diff to previous 1.428
changes to support dynamic sims and updates
Revision 1.428 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 18 17:41:13 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.427: +34 -0 lines
Diff to previous 1.427
RAE: Adding NMPDR checkbox to subsys.cgi
Revision 1.427 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 18 17:14:07 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.426: +36 -2 lines
Diff to previous 1.426
Revision 1.426 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 16 00:22:42 2006 UTC (13 years, 10 months ago) by efrank
Changes since 1.425: +49 -7 lines
Diff to previous 1.425
=head3 by_raw_alias
usage: $peg = $fig->by_raw_alias($alias)
Returns all FIG ids having the given alias.  Unlike by_alias, we do not attempt any
kind of normalization.  I'm not sure this function is needed, but by_alias searches
only in ext_alias table whereas here I'm searching in the features table.  ext_alias
does not have all external aliases which is keeping my code from working.  In partic\
ular,
it lacks EnsemblGene.  It would be nice to combine these two functions.  -Ed
=cut
=head3 get_cv_attributes
A simple wrapper around get_attriubtes to return only those attributes
that have meta_data indicating that the key is a controlled vocabulary.
See get_attributes for description of arguments and return types.
=cut
Revision 1.425 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jan 15 19:11:31 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.424: +2 -2 lines
Diff to previous 1.424
correction to is_deleted_fid
Revision 1.424 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jan 15 15:11:46 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.423: +2 -0 lines
Diff to previous 1.423
is_deleted_fid should return 0, if the argument is not a fid
Revision 1.423 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Jan 14 23:55:45 2006 UTC (13 years, 10 months ago) by golsen
Changes since 1.422: +1 -1 lines
Diff to previous 1.422
Fine tuning of the add a feature software.  (Still more to come in dealing
with previously deleted features)
Revision 1.422 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jan 13 22:15:35 2006 UTC (13 years, 10 months ago) by golsen
Changes since 1.421: +26 -16 lines
Diff to previous 1.421
Minor changes to assign_function:
   Convert user of form master:xxx to master (clearly the intent)
   Clean-up and clarify flow
Revision 1.421 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jan 13 20:22:39 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.420: +200 -70 lines
Diff to previous 1.420
fixes to deleted_features, replace_features_with, etc
Revision 1.420 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jan 13 06:54:49 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.419: +8 -9 lines
Diff to previous 1.419
Converted the relative-to-absolute path code to use a system-independent PERL utility.
Revision 1.419 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jan 12 23:48:15 2006 UTC (13 years, 10 months ago) by golsen
Changes since 1.418: +101 -52 lines
Diff to previous 1.418
Greatly enhanced error checking and reporting for add_feature.
Make sure feature does not already exist (return existing fid if
this is the case).
Revision 1.418 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jan 12 04:14:24 2006 UTC (13 years, 10 months ago) by golsen
Changes since 1.417: +50 -20 lines
Diff to previous 1.417
Running version of adding a feature with a fid from the clearinghouse.
Revision 1.417 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 11 22:58:57 2006 UTC (13 years, 10 months ago) by olson
Changes since 1.416: +30 -0 lines
Diff to previous 1.416
add_Feature additions
Revision 1.416 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 10 16:45:24 2006 UTC (13 years, 10 months ago) by olson
Changes since 1.415: +10 -1 lines
Diff to previous 1.415
fix to verify_dir
Revision 1.415 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jan 5 01:16:45 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.414: +7 -10 lines
Diff to previous 1.414
RAE: Correcting what is meant by non-zero variant code
Revision 1.414 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 3 18:32:04 2006 UTC (13 years, 11 months ago) by efrank
Changes since 1.413: +48 -0 lines
Diff to previous 1.413
add subsystems_having_organisms
Revision 1.413 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 2 23:58:49 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.412: +1 -1 lines
Diff to previous 1.412
RAE: Adding statistics to protein families
Revision 1.412 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Dec 30 11:52:40 2005 UTC (13 years, 11 months ago) by heiko
Changes since 1.411: +83 -0 lines
Diff to previous 1.411
added best_bbh_candidates_additional function
Revision 1.411 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Dec 24 21:03:57 2005 UTC (13 years, 11 months ago) by overbeek
Changes since 1.410: +4 -4 lines
Diff to previous 1.410
serious problem in setting max_expand in FIG::sims
Revision 1.410 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Dec 21 23:51:50 2005 UTC (13 years, 11 months ago) by overbeek
Changes since 1.409: +60 -2 lines
Diff to previous 1.409
Revision 1.409 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Dec 20 17:59:08 2005 UTC (13 years, 11 months ago) by overbeek
Changes since 1.408: +39 -1 lines
Diff to previous 1.408
add abstract functional coupling
Revision 1.408 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Dec 10 23:05:58 2005 UTC (13 years, 11 months ago) by overbeek
Changes since 1.407: +26 -0 lines
Diff to previous 1.407
RAE: extending protein families
Revision 1.407 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Dec 10 18:08:17 2005 UTC (13 years, 11 months ago) by overbeek
Changes since 1.406: +20 -20 lines
Diff to previous 1.406
RAE: Changed attribute key to tag throughout
Revision 1.406 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Dec 8 18:07:54 2005 UTC (13 years, 11 months ago) by parrello
Changes since 1.405: +13 -0 lines
Diff to previous 1.405
Added a method that can be used to determine whether the data is being taken from SEED or NMPDR.
Revision 1.405 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Dec 6 06:57:17 2005 UTC (14 years ago) by overbeek
Changes since 1.404: +28 -0 lines
Diff to previous 1.404
Updating protein families
Revision 1.404 - (view) (download) (as text) (annotate) - [select for diffs]
Changes since 1.403: +17 -0 lines
Diff to previous 1.403
Added license words.
Revision 1.403 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Dec 2 20:13:44 2005 UTC (14 years ago) by olson
Changes since 1.402: +16 -1 lines
Diff to previous 1.402
Don't save absolute paths in file_table in database; rather, strip them on file2N and restore on N2file.
Revision 1.402 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Dec 1 22:28:13 2005 UTC (14 years ago) by overbeek
Changes since 1.401: +7 -1 lines
Diff to previous 1.401
Making attributes work for Ed
Revision 1.401 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Nov 28 02:01:18 2005 UTC (14 years ago) by overbeek
Changes since 1.400: +1 -1 lines
Diff to previous 1.400
minor fix in reconizing aliases
Revision 1.400 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Nov 27 22:17:15 2005 UTC (14 years ago) by overbeek
Changes since 1.399: +2 -2 lines
Diff to previous 1.399
correcting tag names
Revision 1.399 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Nov 24 02:12:41 2005 UTC (14 years ago) by overbeek
Changes since 1.398: +88 -33 lines
Diff to previous 1.398
updating subsys.cgi so that it works with attributes again. Quickly, this time
Revision 1.398 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Nov 24 01:00:45 2005 UTC (14 years ago) by overbeek
Changes since 1.397: +33 -5 lines
Diff to previous 1.397
correcting and extending get_distinct_keys
Revision 1.397 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 23 23:24:11 2005 UTC (14 years ago) by overbeek
Changes since 1.396: +11 -3 lines
Diff to previous 1.396
correcting return when no data supplied
Revision 1.396 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 23 23:05:25 2005 UTC (14 years ago) by overbeek
Changes since 1.395: +16 -8 lines
Diff to previous 1.395
removing error messages from attributes
Revision 1.395 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 23 20:34:59 2005 UTC (14 years ago) by overbeek
Changes since 1.394: +287 -310 lines
Diff to previous 1.394
major changes to attributes and protein families. There are changes to several modules to deal with new attributes database, and simultaneous updates to protein families
Revision 1.394 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 23 17:49:12 2005 UTC (14 years ago) by parrello
Changes since 1.393: +609 -3 lines
Diff to previous 1.393
Added access methods for the UserData object.
Fixed some documentation.
Revision 1.393 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Nov 22 14:57:50 2005 UTC (14 years ago) by overbeek
Changes since 1.392: +5 -4 lines
Diff to previous 1.392
fixes to characterization of hypos
Revision 1.392 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Nov 10 20:16:07 2005 UTC (14 years ago) by efrank
CVS Tags: caBIG-00-00-00
Changes since 1.391: +1 -1 lines
Diff to previous 1.391
move cv files from Global to Global/CV
Revision 1.391 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Nov 10 19:56:33 2005 UTC (14 years ago) by efrank
Changes since 1.390: +32 -0 lines
Diff to previous 1.390
add search_cv_file as an encapsulation.
   cv, search_term -> ( (cv, term_id,term), ... )
I also have changes in index searching that I'm trying _not_ to commit.
If you see wierdness, i messed up the commit so yell at me.
Revision 1.390 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 2 21:39:25 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.389: +126 -36 lines
Diff to previous 1.389
Rewrote some ENV tests to avoid compiler warnings.
Removed redundant variable declarations to avoid compiler warnings.
Added a new method to test whether a role ID is an EC number.
Revision 1.389 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Oct 28 16:05:02 2005 UTC (14 years, 1 month ago) by olson
Changes since 1.388: +1 -1 lines
Diff to previous 1.388
Strip  xxx identifiers from feature_aliases output.
Revision 1.388 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Oct 28 16:03:12 2005 UTC (14 years, 1 month ago) by olson
Changes since 1.387: +62 -0 lines
Diff to previous 1.387
Add run_gathering_output() for safe backtick-like  functionality.
Revision 1.387 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 27 16:20:34 2005 UTC (14 years, 1 month ago) by efrank
Changes since 1.386: +16 -1 lines
Diff to previous 1.386
make add_cv_term give error status if passed empty strings.
make search_index_by_attribute be case insensitive.
How do you do this on just one line?  Right now I used 2 lines (a bunch of times)
     $user =~ s/^\s*//g;
     $user =~ s/\s*$//g;
Revision 1.386 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Oct 26 22:12:03 2005 UTC (14 years, 1 month ago) by efrank
Changes since 1.385: +37 -4 lines
Diff to previous 1.385
key_info:  modify to return  nothing if the passed key has no associated
	   data (rather than returning empty hash).
search_index:  modify to call search_index_by_attributes so that attributes are
	   included in the search without building glimpse indexes
search_index_by_attribues:   supports search_index.
Also, in search_index, turned off old attribute search.
Revision 1.385 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Oct 26 19:33:11 2005 UTC (14 years, 1 month ago) by efrank
Changes since 1.384: +7 -3 lines
Diff to previous 1.384
key_info() was returning and empty hash to say it had nothing that matches
a key.  this was making downstream code very confusing.  so now i return
nothing if there's no match for the key.
Revision 1.384 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Oct 26 16:38:12 2005 UTC (14 years, 1 month ago) by efrank
Changes since 1.383: +76 -0 lines
Diff to previous 1.383
add new sub, add_cv_term($user, $peg, $vocab, $id, $term);
=head3 add_cv_term
Add a controlled vocabulary term to a peg.  Pass in the peg, the vocab
name, the termId, and the term (see next paragraph).  returns error string
if problem, else returns nothing.
   my $status = $fig->add_cv_term( "master:EdF",
   				   "fig|9606.3.peg.26823", "MyVocab", "1234", "A thing of wonder.");
				      if ($status) {print "error adding cv term: $status\n";}
				      Controlled vocabulary is read-only text associated with a peg.  Each
				      is a triple, namely (vocab name, termId, term text).  The termId is an
				      id that is used in the particulary vocabulary and the term text is the
				      actual term.  For example, the GO has the term "U12-type nuclear mRNA
				      branch site recognition" with termId GO:0000371.  Thus, the triplet is
				      (GO, GO:0000371, "U12-type nuclear mRNA branch site recognition").
				      Don't be confused by the GO: in GO:0000371.  We don't add the GO:.
				      That's just what GO decided to do.
				      termIds can not have ';' in them.
				      This routine encapsulates our present implementation via attributes.
				      =cut
Revision 1.383 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Oct 25 14:50:23 2005 UTC (14 years, 1 month ago) by overbeek
Changes since 1.382: +45 -10 lines
Diff to previous 1.382
protein families again
Revision 1.382 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 24 21:50:35 2005 UTC (14 years, 1 month ago) by overbeek
Changes since 1.381: +40 -0 lines
Diff to previous 1.381
Assorted relative-path fixes.
remove length check in indexing function assignments.
Revision 1.381 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 24 19:36:38 2005 UTC (14 years, 1 month ago) by mkubal
Changes since 1.380: +10 -4 lines
Diff to previous 1.380
fixed key_info
Revision 1.380 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Oct 22 17:43:49 2005 UTC (14 years, 1 month ago) by overbeek
Changes since 1.379: +41 -14 lines
Diff to previous 1.379
changing the format of attribute_keys
Revision 1.379 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 20 10:22:04 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.378: +171 -57 lines
Diff to previous 1.378
Added new documentation.
Fixed attributes to prevent return of duplicate items.
Revision 1.378 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 13 20:13:48 2005 UTC (14 years, 1 month ago) by overbeek
Changes since 1.377: +12 -2 lines
Diff to previous 1.377
Workaround for peg.synonyms file that has multiple entries.
Revision 1.377 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Oct 12 21:03:16 2005 UTC (14 years, 1 month ago) by overbeek
Changes since 1.376: +14 -2 lines
Diff to previous 1.376
Revision 1.376 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Oct 12 02:28:16 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.375: +137 -1 lines
Diff to previous 1.375
Added the "compute_clusters" method for use by UnvSubsys.
Added a "FIG" method for compatability with SFXlate.
Added more documentation.
Revision 1.375 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Oct 11 20:38:38 2005 UTC (14 years, 1 month ago) by efrank
Changes since 1.374: +24 -0 lines
Diff to previous 1.374
add find_by_attribute.  this takes a single string argument.  it returns
triples, (featureId, key, value) of all attributes in which the search string
is a substring of either key or value.  the search is via the attribute table,
not via the glimpse indexes so tha searches immediately after edits of
attributes work.
Revision 1.374 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Oct 8 14:14:47 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.373: +1 -1 lines
Diff to previous 1.373
minor fix to not include xxx entries in expanded sims
Revision 1.373 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 6 22:44:02 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.372: +17 -2 lines
Diff to previous 1.372
adding more functions with external ids
Revision 1.372 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 6 21:22:48 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.371: +47 -0 lines
Diff to previous 1.371
loading external ids and external protein families
Revision 1.371 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 6 02:22:41 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.370: +0 -2 lines
Diff to previous 1.370
remove debug
Revision 1.370 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Oct 5 20:34:02 2005 UTC (14 years, 2 months ago) by overbeek
CVS Tags: caBIG-dataload-0
Changes since 1.369: +71 -8 lines
Diff to previous 1.369
fixes to update_uniq_id_data
Revision 1.369 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Sep 18 14:27:13 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.368: +4 -1 lines
Diff to previous 1.368
fix display_subsys.cgi
Revision 1.368 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 14 20:04:19 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.367: +6 -2 lines
Diff to previous 1.367
Correcting display of classifications
Revision 1.367 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Sep 11 17:02:40 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.366: +19 -0 lines
Diff to previous 1.366
fixes to display of reactions
Revision 1.366 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Sep 11 16:34:41 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.365: +20 -0 lines
Diff to previous 1.365
add functiontion to FIG.pm to get active subsystems for a genome
Revision 1.365 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Sep 10 07:39:18 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.364: +1816 -1816 lines
Diff to previous 1.364
Converted tabs to spaces to fix indenting.
Revision 1.364 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 9 13:28:58 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.363: +23 -5 lines
Diff to previous 1.363
upgrade sigs.cgi to run under Sprout
Revision 1.363 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 8 16:12:22 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.362: +3 -2 lines
Diff to previous 1.362
Added `formatdb` invocation to &add_genome(). Changed "VERBOSE" flag name to "FIG_VERBOSE". -- /gdp
Revision 1.362 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 6 19:58:53 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.361: +2 -1 lines
Diff to previous 1.361
make annotation requests by master return all non-assignment annotations.
Revision 1.361 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 6 18:52:35 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.360: +117 -27 lines
Diff to previous 1.360
Make annotations_made_fast return new Annotation objects instead of arrays of data.
Add the Annotation object.
Revision 1.360 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 2 22:23:33 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.359: +2 -5 lines
Diff to previous 1.359
Remove the debugging file setting in add_annotations_batch.
Revision 1.359 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 2 22:21:57 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.358: +129 -0 lines
Diff to previous 1.358
Add $fig->add_annotations_batch() that does filehandle conservation and uses COPY TABLE instead
of INSERT to add annotations to the database. Now used by 'fig add_annotations' so that
large annotation file installs don't take overnight.
Revision 1.358 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 1 20:52:51 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.357: +12 -3 lines
Diff to previous 1.357
Force is_deleted_fid to set the value of $/ that it wants, since use of that method
within a loop with $/ set to something else breaks is_deleted_fid. Darn global input
record separator.
Revision 1.357 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 1 19:23:49 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.356: +95 -14 lines
Diff to previous 1.356
Add FIG::by_genome_id for sorting genome ID lists.
Add $fig->extract_assignments_from_annoatations to transform the output of annotations_made_fast
to a list of the current assignments (per the annotations data).
Revision 1.356 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 1 18:14:53 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.355: +96 -9 lines
Diff to previous 1.355
make package_annotations use $fig->annotations_made_fast.
Add date parsing to FIG.pm ($fig->parse_date) using Date::Parse if available.
Revision 1.355 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 1 09:30:07 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.354: +191 -64 lines
Diff to previous 1.354
Tweaked tracing, added more documentation, fixed so that the annotations will work properly in environments where the number of characters in a file is different from the number of bytes.
Revision 1.354 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Aug 30 18:04:55 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.353: +1 -1 lines
Diff to previous 1.353
Fixed &possibly_truncated() so that it does not blow up on non-PEG features. -- /gdp
Revision 1.353 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Aug 30 07:27:59 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.352: +20 -2 lines
Diff to previous 1.352
Invoked `assess_completeness` from &add_genomes(). -- /gdp
Revision 1.352 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 22 05:43:02 2005 UTC (14 years, 3 months ago) by redwards
Changes since 1.351: +5 -3 lines
Diff to previous 1.351
Adding menus to subsys.cgi
Revision 1.351 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Aug 20 12:32:29 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.350: +2 -1 lines
Diff to previous 1.350
fixes to calling starts
Revision 1.350 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Aug 20 02:37:22 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.349: +5 -3 lines
Diff to previous 1.349
fixes to call_starts
Revision 1.349 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Aug 19 19:52:19 2005 UTC (14 years, 3 months ago) by redwards
Changes since 1.348: +10 -6 lines
Diff to previous 1.348
Adding more details to organisms.cgi and correcting get_key_values
Revision 1.348 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Aug 17 03:15:01 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.347: +2 -0 lines
Diff to previous 1.347
removing blank lines from attribute_keys
Revision 1.347 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Aug 16 19:41:12 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.346: +2 -1 lines
Diff to previous 1.346
NMPDR updates
Revision 1.346 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 15 21:41:29 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.345: +3 -1 lines
Diff to previous 1.345
Revision 1.345 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 15 21:34:53 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.344: +12 -10 lines
Diff to previous 1.344
Fixed change_attribute to work properly if the attribute value has quotes in it.
Revision 1.344 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 15 21:16:19 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.343: +1 -1 lines
Diff to previous 1.343
Fixed "add_attributes" to work correctly when quotes are present in attribute values.
Revision 1.343 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 15 20:25:02 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.342: +6 -2 lines
Diff to previous 1.342
Modified &to_aliases to make "TYPE" argument optional instead of mandatory. -- /gdp
Revision 1.342 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Aug 9 00:56:02 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.341: +1 -1 lines
Diff to previous 1.341
Changed "add_feature" to save the return from the INSERT into the feature table so that it can be viewed during debugging.
Revision 1.341 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 8 21:54:39 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.340: +2 -1 lines
Diff to previous 1.340
More diagram changes.
Add new simple start page.
Revision 1.340 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 8 20:04:33 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.339: +63 -34 lines
Diff to previous 1.339
Updated "add_feature" to allow the caller to specify the feature ID.
Revision 1.339 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 8 18:43:08 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.338: +41 -0 lines
Diff to previous 1.338
adding fig versus kegg
Revision 1.338 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Aug 7 22:06:58 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.337: +2 -1 lines
Diff to previous 1.337
fix to multi-functional roles
Revision 1.337 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Aug 6 15:30:29 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.336: +30 -3 lines
Diff to previous 1.336
New interface for subsys.cgi, but it is commented out at the moment
Revision 1.336 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Aug 6 14:58:56 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.335: +64 -5 lines
Diff to previous 1.335
fixes to bugs in calling starts
Revision 1.335 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Aug 5 13:14:26 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.334: +7 -3 lines
Diff to previous 1.334
adding options to add_genome
Revision 1.334 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Aug 4 18:28:36 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.333: +8 -3 lines
Diff to previous 1.333
Make enqueue_similarities ignore a $fig argument if invoked as a method call.
Add a $time_made argument to add_annotation.
Revision 1.333 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Aug 4 01:27:25 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.332: +5 -1 lines
Diff to previous 1.332
Modified &possibly_truncated() to accept either FID or location. -- /gdp
Revision 1.332 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Aug 4 01:20:59 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.331: +20 -12 lines
Diff to previous 1.331
Revision 1.331 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Aug 3 23:00:37 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.330: +10 -3 lines
Diff to previous 1.330
Adding a force to the add_genomes
Revision 1.330 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Aug 3 21:16:29 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.329: +24 -13 lines
Diff to previous 1.329
Support gif/png/jpeg file type detection on diagram upload.
Support the multiple file types on packaging for clearinghouse.
Revision 1.329 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Aug 3 17:40:42 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.328: +47 -1 lines
Diff to previous 1.328
Add support for creating and parsing diagram data as part of subsystem clearinghouse packages.
Revision 1.328 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 1 22:23:15 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.327: +42 -42 lines
Diff to previous 1.327
Changed attributes to capital-case in order to prevent the avalanche of compile-time warnings.
Revision 1.327 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 1 18:52:58 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.326: +7 -8 lines
Diff to previous 1.326
update stuff relating to protein families
Revision 1.326 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jul 31 17:08:02 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.325: +21 -16 lines
Diff to previous 1.325
Cosmetic changes to make clear that &display_id_and_seq() and &display_seq() take sequence-pointers, not sequences. -- /gdp
Revision 1.325 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jul 31 01:09:59 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.324: +30 -9 lines
Diff to previous 1.324
 fixes to pick_gene_boundaries
Revision 1.324 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 29 22:27:46 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.323: +40 -0 lines
Diff to previous 1.323
Publish/install changes for reactions.
Revision 1.323 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 29 18:13:11 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.322: +27 -2 lines
Diff to previous 1.322
Support "fig load_all N" and "fig load_all list"
Revision 1.322 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jul 28 18:03:24 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.321: +72 -0 lines
Diff to previous 1.321
commit code to expand regions of similarity to PEGs and to recall starts
Revision 1.321 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jul 27 19:41:56 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.320: +1 -3 lines
Diff to previous 1.320
Fixed some POD comments.
Revision 1.320 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 26 20:06:03 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.319: +380 -111 lines
Diff to previous 1.319
Added "upstream_of" method to compute upstream sequences.
Cleaned up some documentation.
Revision 1.319 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 26 04:53:36 2005 UTC (14 years, 4 months ago) by mkubal
Changes since 1.318: +1 -1 lines
Diff to previous 1.318
7-26-05
Revision 1.318 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Jul 23 19:47:36 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.317: +3 -1 lines
Diff to previous 1.317
altering location in FIG.pm
Revision 1.317 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 19 16:29:35 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.316: +4 -4 lines
Diff to previous 1.316
standardize returned DNA to lower case, as per GJO's request. -- /gdp
Revision 1.316 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 19 16:14:21 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.315: +2 -1 lines
Diff to previous 1.315
More final touches for Attributes code
Revision 1.315 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 19 05:26:12 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.314: +2 -2 lines
Diff to previous 1.314
minor chagnes to attributes
Revision 1.314 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 19 04:54:21 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.313: +36 -9 lines
Diff to previous 1.313
Updating attributes code in seed
Revision 1.313 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jul 18 03:12:11 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.312: +54 -9 lines
Diff to previous 1.312
Revision 1.312 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jul 17 19:04:27 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.311: +63 -29 lines
Diff to previous 1.311
Making attributes interface work
Revision 1.311 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jul 13 01:49:54 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.310: +22 -37 lines
Diff to previous 1.310
minor changes to subsys_vectors to allow complete genomes
Revision 1.310 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 12 22:10:07 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.309: +14 -0 lines
Diff to previous 1.309
minor changes to subsys_vectors.cgi
Revision 1.309 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 12 14:34:14 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.308: +91 -40 lines
Diff to previous 1.308
Changing attributes and modifying protein.cgi with show/hides
Revision 1.308 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 12 00:34:32 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.307: +16 -16 lines
Diff to previous 1.307
updates to build protein families
Revision 1.307 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jul 10 04:59:11 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.306: +8 -1 lines
Diff to previous 1.306
making index_subsystems work
Revision 1.306 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Jul 9 21:46:15 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.305: +17 -0 lines
Diff to previous 1.305
added index subsystems to subsys.cgi
Revision 1.305 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 1 02:09:16 2005 UTC (14 years, 5 months ago) by redwards
Changes since 1.304: +46 -26 lines
Diff to previous 1.304
Changed proteinfamilies.cgi
Revision 1.304 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 29 15:06:12 2005 UTC (14 years, 5 months ago) by olson
CVS Tags: merge-trunktag-bobdev_news-2
Changes since 1.303: +2 -2 lines
Diff to previous 1.303
Tweak tracing.
Revision 1.303 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 29 00:28:01 2005 UTC (14 years, 5 months ago) by redwards
Changes since 1.302: +88 -5 lines
Diff to previous 1.302
Initial release of proteinfamilies.cgi into the wild
Revision 1.302 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 28 17:25:04 2005 UTC (14 years, 5 months ago) by redwards
Changes since 1.301: +20 -0 lines
Diff to previous 1.301
commiting FIG.pm::clean_spaces to remove leading, trailing, and extra spaces. Please use it
Revision 1.301 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jun 24 21:39:14 2005 UTC (14 years, 5 months ago) by parrello
CVS Tags: merge-trunktag-bobdev_news-1
Changes since 1.300: +16 -17 lines
Diff to previous 1.300
Fixed the environment-variable tracing so that it does not override previous tracing options if they were set.
Revision 1.300 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 23 21:24:48 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.299: +5 -0 lines
Diff to previous 1.299
finally
Revision 1.299 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 23 19:35:07 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.298: +33 -2 lines
Diff to previous 1.298
Add some more gene  name mapping stuff.
Add Tracer environment variable for affecting tracing.
Fix typo in invocation of load_coupling.
Revision 1.298 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 22 21:00:24 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.297: +514 -531 lines
Diff to previous 1.297
Replaced tabs with spaces to make indenting device-independent.
Moved "Open" and "OpenDir" to the Tracer.pm module.
Added more POD documentation.
Revision 1.297 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 20 21:58:56 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.296: +63 -0 lines
Diff to previous 1.296
Add genome/peg id mapping routines. (For functional coupling support).
Revision 1.296 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 20 17:08:32 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.295: +1 -1 lines
Diff to previous 1.295
add new protein family routines
Revision 1.295 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 20 17:04:45 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.294: +72 -11 lines
Diff to previous 1.294
Revision 1.294 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 20 04:03:44 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.293: +6 -1 lines
Diff to previous 1.293
disable old protein families
Revision 1.293 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 13 16:43:48 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: Root-bobdev_news
Changes since 1.292: +20 -33 lines
Diff to previous 1.292
Ross change commit after cleanup
Revision 1.292 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 13 09:32:09 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.291: +160 -2 lines
Diff to previous 1.291
Added Open and OpenDir methods for streamlining file and directory operations.
Revision 1.291 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jun 10 16:08:52 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.290: +7 -7 lines
Diff to previous 1.290
fixes to cached pin displays
Revision 1.290 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jun 10 15:36:37 2005 UTC (14 years, 5 months ago) by redwards
Changes since 1.289: +7 -9 lines
Diff to previous 1.289
adding correspondence.cgi
Revision 1.289 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 9 20:03:15 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.288: +95 -1 lines
Diff to previous 1.288
re-add couipling routines
Revision 1.288 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 9 18:39:05 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.287: +39 -28 lines
Diff to previous 1.287
Revision 1.287 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 9 05:36:30 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.286: +2333 -1628 lines
Diff to previous 1.286
Revision 1.286 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 8 23:05:21 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.285: +7 -30 lines
Diff to previous 1.285
major change to BBHs (use precomputed)
Revision 1.285 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 7 16:41:23 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.284: +2 -1 lines
Diff to previous 1.284
Fixed typo in &hypo(), and added new rule. -- /gdp
Revision 1.284 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 1 01:18:50 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.283: +91 -12 lines
Diff to previous 1.283
Revision 1.283 - (view) (download) (as text) (annotate) - [select for diffs]
Sun May 29 13:33:56 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.282: +24 -0 lines
Diff to previous 1.282
add test for existence of relation that works only under Postgres
Revision 1.282 - (view) (download) (as text) (annotate) - [select for diffs]
Wed May 25 18:58:27 2005 UTC (14 years, 6 months ago) by redwards
Changes since 1.281: +39 -0 lines
Diff to previous 1.281
added subsystems_roles method to FIG.pm
Revision 1.281 - (view) (download) (as text) (annotate) - [select for diffs]
Wed May 25 16:07:23 2005 UTC (14 years, 6 months ago) by olson
Changes since 1.280: +92 -0 lines
Diff to previous 1.280
Code for similarity request export.
Revision 1.280 - (view) (download) (as text) (annotate) - [select for diffs]
Fri May 20 11:23:07 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.279: +1 -1 lines
Diff to previous 1.279
fix bug in search_indexes
Revision 1.279 - (view) (download) (as text) (annotate) - [select for diffs]
Tue May 17 16:04:08 2005 UTC (14 years, 6 months ago) by olson
Changes since 1.278: +307 -19 lines
Diff to previous 1.278
Revision 1.278 - (view) (download) (as text) (annotate) - [select for diffs]
Tue May 10 12:03:39 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.277: +4 -1 lines
Diff to previous 1.277
fixes to using trees under subsystems
Revision 1.277 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 5 17:43:03 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.276: +5 -3 lines
Diff to previous 1.276
fix indexing search code
Revision 1.276 - (view) (download) (as text) (annotate) - [select for diffs]
Tue May 3 21:03:38 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.275: +1 -1 lines
Diff to previous 1.275
add css generation modules
Revision 1.275 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Apr 29 16:43:29 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.274: +1 -0 lines
Diff to previous 1.274
add assign_to_close_strains
Revision 1.274 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Apr 18 18:29:31 2005 UTC (14 years, 7 months ago) by mkubal
Changes since 1.273: +2 -3 lines
Diff to previous 1.273
revised on Monday
Revision 1.273 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Apr 18 06:26:04 2005 UTC (14 years, 7 months ago) by redwards
Changes since 1.272: +1 -1 lines
Diff to previous 1.272
minor fix to select tag/values
Revision 1.272 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Apr 18 06:19:40 2005 UTC (14 years, 7 months ago) by redwards
Changes since 1.271: +3 -1 lines
Diff to previous 1.271
Revision 1.271 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Apr 17 16:30:19 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.270: +2 -0 lines
Diff to previous 1.270
handle missing annotations file gracefully
Revision 1.270 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Apr 15 23:23:13 2005 UTC (14 years, 7 months ago) by golsen
Changes since 1.269: +7 -27 lines
Diff to previous 1.269
Fix bunged index search
Revision 1.269 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Apr 14 18:52:19 2005 UTC (14 years, 7 months ago) by mkubal
Changes since 1.268: +2 -1 lines
Diff to previous 1.268
search_index now returns attributes
Revision 1.268 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Apr 13 15:37:30 2005 UTC (14 years, 7 months ago) by redwards
Changes since 1.267: +30 -21 lines
Diff to previous 1.267
changed genome stats to show attributes
Revision 1.267 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Apr 10 03:32:30 2005 UTC (14 years, 7 months ago) by golsen
Changes since 1.266: +1 -1 lines
Diff to previous 1.266
Re-enable "duplicates" in sims.  Multiple regions of matching is common
in eukaryotic sequences, and only seeing one is disorienting.
Revision 1.266 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Apr 8 20:22:23 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.265: +10 -15 lines
Diff to previous 1.265
changed tag/value pairs completely. Ooops!
Revision 1.265 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Apr 7 19:16:10 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.264: +30 -15 lines
Diff to previous 1.264
many changes to key/value pairs to make them work
Revision 1.264 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Apr 3 19:43:41 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.263: +5 -2 lines
Diff to previous 1.263
changing pir corresepondence
Revision 1.263 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Apr 3 19:11:11 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.262: +97 -8 lines
Diff to previous 1.262
Added a script to load pir superfamilies in the background. This will download all the data and install it. Changed pir.cgi to background this job as it takes a while.
Revision 1.262 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Apr 2 11:56:12 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.261: +2 -0 lines
Diff to previous 1.261
add update_subsys_conflicts to fig.pl
Revision 1.261 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Mar 31 18:05:28 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.260: +3 -0 lines
Diff to previous 1.260
fix to asses_completeness
Revision 1.260 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Mar 30 19:58:20 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.259: +27 -0 lines
Diff to previous 1.259
Add genome_with_md5sum.
Warn on FigGFF errors only if you're bob.
Revision 1.259 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Mar 30 15:53:37 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.258: +4 -4 lines
Diff to previous 1.258
changing attributes returned back to variables
Revision 1.258 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Mar 29 20:41:17 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.257: +7 -5 lines
Diff to previous 1.257
minor changes to rae.cgi
Revision 1.257 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Mar 29 19:29:39 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.256: +3 -2 lines
Diff to previous 1.256
add make_pu from ids and seqs
Revision 1.256 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Mar 29 18:42:26 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.255: +7 -0 lines
Diff to previous 1.255
broaden set of acceptable aliases as dbxrefs
Revision 1.255 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Mar 23 18:54:39 2005 UTC (14 years, 8 months ago) by golsen
Changes since 1.254: +1 -1 lines
Diff to previous 1.254
Removed constraint that sims request had to be by a fig ID.  Ross seems to
have solved the orginal problem that names that could not be mapped
returned a representitive ID with undefined length, which crashed sims().
Now failure to map a name returns an empty list, and sims graceful returns
an empty list of similarities.
Revision 1.254 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Mar 21 22:01:22 2005 UTC (14 years, 8 months ago) by golsen
Changes since 1.253: +0 -1 lines
Diff to previous 1.253
A few similarities tweeks.  Move the submit button on the default protein
page (to shorten the line slightly).  Remove a debug statement that was
writing to the error log.
Revision 1.253 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Mar 21 21:39:32 2005 UTC (14 years, 8 months ago) by golsen
Changes since 1.252: +7 -4 lines
Diff to previous 1.252
Add options to Similarities to override Max expand when asking for FIG IDs.
It gets annoying to have to constantly increase the value, and it is not
predictable how many sims will need to be expanded to get any desired
number of FIG IDs.
Revision 1.252 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Mar 21 18:33:49 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.251: +1 -1 lines
Diff to previous 1.251
fix to best_bbh_candidates and added fill_subsys
Revision 1.251 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Mar 20 22:26:16 2005 UTC (14 years, 8 months ago) by golsen
Changes since 1.250: +36 -2 lines
Diff to previous 1.250
When sorting similarities by percent identity or bit score per position,
include a penalty for very sort sequences, so that they do not randomly
appear much higher in the similaries list than they should.  The current
treatment for this is roughly a two standard deviation penalty.
The original behavior is still available as non-star versions.
The "help" information has been updated (and other aspects clarified
as well).
Revision 1.250 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Mar 19 01:27:13 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.249: +4 -0 lines
Diff to previous 1.249
update hypo
Revision 1.249 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Mar 16 17:56:22 2005 UTC (14 years, 8 months ago) by golsen
Changes since 1.248: +2 -2 lines
Diff to previous 1.248
Fix end condition test on expand_raw_sims to promptly return.
Revision 1.248 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Mar 16 15:17:45 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.247: +1 -0 lines
Diff to previous 1.247
remove ddd: in front of some organisms (mostly uniprot)
Revision 1.247 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Mar 16 15:11:56 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.246: +2 -1 lines
Diff to previous 1.246
change spaces to _s in subsystem names
Revision 1.246 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Mar 16 00:18:09 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.245: +1 -1 lines
Diff to previous 1.245
make the gff stuff work again.
Revision 1.245 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Mar 15 23:56:53 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.244: +76 -1 lines
Diff to previous 1.244
Put the FigGFF code in a require for now.
Add fast anno lookup.
Revision 1.244 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Mar 14 19:17:37 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.243: +13 -0 lines
Diff to previous 1.243
Add general-purpose GFF writing stuff.
Revision 1.243 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Mar 14 02:04:44 2005 UTC (14 years, 8 months ago) by golsen
Changes since 1.242: +3 -3 lines
Diff to previous 1.242
Minor fix in expand_raw_sims so that it stops when it should
Revision 1.242 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Mar 13 00:55:21 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.241: +59 -17 lines
Diff to previous 1.241
Initial commit of organisms.cgi which allows separate entry pages for different groups of organisms
Revision 1.241 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Mar 11 22:03:13 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.240: +10 -2 lines
Diff to previous 1.240
fix for mapped_prot_ids
Revision 1.240 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Mar 11 04:11:30 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.239: +4 -5 lines
Diff to previous 1.239
Making tag/value pairs work
Revision 1.239 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Mar 11 03:04:32 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.238: +12 -5 lines
Diff to previous 1.238
Revision 1.238 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Mar 11 01:04:32 2005 UTC (14 years, 8 months ago) by golsen
Changes since 1.237: +247 -122 lines
Diff to previous 1.237
Many new options for similarities
Revision 1.237 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Mar 8 21:14:53 2005 UTC (14 years, 9 months ago) by olson
Changes since 1.236: +19 -1 lines
Diff to previous 1.236
Add contig_md5sum.
Revision 1.236 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Mar 8 21:06:04 2005 UTC (14 years, 9 months ago) by olson
Changes since 1.235: +30 -0 lines
Diff to previous 1.235
Add support for computing MD5 checksums for contigs and genomes.
The checksum of a genome is defined as the checksum of its signature file. The signature
file consists of tab-separated lines, one for each contig, ordered by the contig id.
Each line contains the contig ID, the length of the contig in nucleotides, and the
MD5 checksum of the nucleotide data, with uppercase letters forced to lower case.
The signature file is written by index_contigs to
The genome's md5 checksum is written by index_contigs to <genomedir>/MD5SUM.
The md5.c code here is extracted from the Perl Digest::MD5 module. We use the perl
configuration to build it so that it will work correctly on 64-bit architectures.
Revision 1.235 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Mar 6 15:10:02 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.234: +1 -0 lines
Diff to previous 1.234
disconnect get_attributes until I can talk to Rob
Revision 1.234 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Mar 5 04:29:59 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.233: +10 -2 lines
Diff to previous 1.233
added highlight by peg attribute to subsystem
Revision 1.233 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Mar 4 23:16:42 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.232: +23 -17 lines
Diff to previous 1.232
tweaks to coloring ss by oa
Revision 1.232 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Mar 4 22:37:06 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.231: +128 -13 lines
Diff to previous 1.231
Added color by organism attributes to subsystems page
Revision 1.231 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Mar 4 18:29:21 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.230: +3 -0 lines
Diff to previous 1.230
Added attribute editing to the protein.cgi page
Revision 1.230 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Mar 4 06:22:10 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.229: +204 -18 lines
Diff to previous 1.229
Big updates to FIG.pm for the addition of methods to properly handle attributes. Also modified genome_statistics to take advantage of these new methods. load_attributes will load genomes and other attributes but doesn't not yet use the new methods (but should), and Attributes.html is some docs.
Revision 1.229 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Feb 27 01:39:55 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.228: +51 -3 lines
Diff to previous 1.228
major changes in notion of function and load_attributes
Revision 1.228 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 26 19:49:59 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.227: +4 -0 lines
Diff to previous 1.227
filters for data mining
Revision 1.227 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 26 11:01:13 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.226: +20 -3 lines
Diff to previous 1.226
add reset_curator.cgi
Revision 1.226 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Feb 16 18:59:20 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.225: +3 -1 lines
Diff to previous 1.225
highlight subsystems with no genomes attached
Revision 1.225 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 12 18:41:04 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.224: +1 -1 lines
Diff to previous 1.224
Fix subsystem_classification in FIG.pm
Revision 1.224 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 12 18:18:14 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.223: +8 -17 lines
Diff to previous 1.223
Moved the subsystem_classification getting/setting into subsys.pm where it belongs, and so I ammended FIG.pm. Also added the boxes on the subsystem page so you can see the classifications.
Revision 1.223 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 12 17:20:43 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.222: +6 -5 lines
Diff to previous 1.222
minor change to FIG::subsystem_classification
Revision 1.222 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 12 06:49:27 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.221: +3 -3 lines
Diff to previous 1.221
Initial addition of subsys_summary.cgi and minor modification of FIG.pm
Revision 1.221 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 12 05:38:43 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.220: +6 -3 lines
Diff to previous 1.220
changes to subsystem_classification
Revision 1.220 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 12 04:51:47 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.219: +9 -14 lines
Diff to previous 1.219
fix routine for locating candidates for a role in a genome
Revision 1.219 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 12 04:08:00 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.218: +35 -0 lines
Diff to previous 1.218
Minor changes to pir.cgi and added subsystem_classification to FIG.pm
Revision 1.218 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 12 04:01:01 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.217: +20 -72 lines
Diff to previous 1.217
many fixes to extending subsystems
Revision 1.217 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 12 03:50:04 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.216: +26 -0 lines
Diff to previous 1.216
Add some pod to FIG.pm
Revision 1.216 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 12 03:00:57 2005 UTC (14 years, 9 months ago) by mkubal
Changes since 1.215: +19 -15 lines
Diff to previous 1.215
update
Revision 1.215 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Feb 11 06:34:05 2005 UTC (14 years, 9 months ago) by mkubal
Changes since 1.214: +85 -3 lines
Diff to previous 1.214
added all_for_genome, etc
Revision 1.214 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Feb 10 13:33:37 2005 UTC (14 years, 9 months ago) by olson
Changes since 1.213: +26 -0 lines
Diff to previous 1.213
Add subsystems_for_genome.
Revision 1.213 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Feb 7 00:27:34 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.212: +76 -14 lines
Diff to previous 1.212
no message
Revision 1.212 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 5 04:12:35 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.211: +1 -1 lines
Diff to previous 1.211
head -1 should be head -n 1
Revision 1.211 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 31 14:01:07 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.210: +2 -1 lines
Diff to previous 1.210
add pegs_in_subsystems
Revision 1.210 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jan 27 00:31:21 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.209: +133 -68 lines
Diff to previous 1.209
no message
Revision 1.209 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 26 18:37:58 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.208: +8 -10 lines
Diff to previous 1.208
fix bugs introduced into by_alias function
Revision 1.208 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jan 23 00:38:22 2005 UTC (14 years, 10 months ago) by golsen
Changes since 1.207: +3 -2 lines
Diff to previous 1.207
Time stamp individual load steps
Revision 1.207 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 18 21:06:41 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.206: +1 -1 lines
Diff to previous 1.206
fix dumb typo.
Revision 1.206 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 18 21:02:45 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.205: +15 -0 lines
Diff to previous 1.205
Add peg_in_gendb and genome_in_gendb
Revision 1.205 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 18 20:55:32 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.204: +6 -0 lines
Diff to previous 1.204
add get_system_name() call.
Revision 1.204 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jan 16 16:05:20 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.203: +16 -2 lines
Diff to previous 1.203
fix to scoring fc
Revision 1.203 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jan 13 17:32:51 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.202: +1 -1 lines
Diff to previous 1.202
More fixes for Sprout integration.
Revision 1.202 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 12 21:22:08 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.201: +2 -1 lines
Diff to previous 1.201
sprout debugging
Revision 1.201 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 12 20:18:56 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.200: +13 -12 lines
Diff to previous 1.200
no message
Revision 1.200 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 12 20:08:30 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.199: +297 -301 lines
Diff to previous 1.199
no message
Revision 1.199 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 11 18:59:39 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.198: +1 -1 lines
Diff to previous 1.198
argument.
Revision 1.198 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jan 9 17:15:12 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.197: +1 -1 lines
Diff to previous 1.197
fix disambiguating maps
Revision 1.197 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Jan 8 18:22:00 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.196: +1 -1 lines
Diff to previous 1.196
add check to assign_function
Revision 1.196 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jan 7 18:55:21 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.195: +2 -2 lines
Diff to previous 1.195
add option to not create a release info file to get_release_info()
Revision 1.195 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 5 16:19:44 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.194: +78 -4 lines
Diff to previous 1.194
p2p changes.
Revision 1.194 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 3 02:23:12 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.193: +0 -1 lines
Diff to previous 1.193
fix stupid error in cleaning up aliases
Revision 1.193 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 3 02:21:08 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.192: +4 -27 lines
Diff to previous 1.192
automatically generate aliases from mapped IDs
Revision 1.192 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Dec 29 17:59:36 2004 UTC (14 years, 11 months ago) by overbeek
Changes since 1.191: +1 -1 lines
Diff to previous 1.191
minor fix to FIG.pm and addition of generate_kegg_map_ec_tables
Revision 1.191 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Dec 16 22:57:43 2004 UTC (14 years, 11 months ago) by overbeek
Changes since 1.190: +2 -1 lines
Diff to previous 1.190
fixes to assigned_function
Revision 1.190 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Dec 15 02:04:34 2004 UTC (14 years, 11 months ago) by overbeek
Changes since 1.189: +9 -5 lines
Diff to previous 1.189
allow set of seeks to cores for bbhs
Revision 1.189 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Dec 13 19:24:15 2004 UTC (14 years, 11 months ago) by redwards
Changes since 1.188: +4 -4 lines
Diff to previous 1.188
Minor changes to FIG.pm POD
Revision 1.188 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Dec 10 07:04:39 2004 UTC (14 years, 11 months ago) by redwards
Changes since 1.187: +18 -0 lines
Diff to previous 1.187
Changes to subsys.cgi that warn if a subsystem doesn't exist
Revision 1.187 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Dec 8 21:28:10 2004 UTC (14 years, 11 months ago) by overbeek
Changes since 1.186: +9 -2 lines
Diff to previous 1.186
raw time for annotations
Revision 1.186 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Dec 6 18:25:18 2004 UTC (15 years ago) by olson
Changes since 1.185: +1 -1 lines
Diff to previous 1.185
fix a comment
Revision 1.185 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Dec 5 16:35:15 2004 UTC (15 years ago) by overbeek
Changes since 1.184: +2 -2 lines
Diff to previous 1.184
add checking for subsystems
Revision 1.184 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Dec 3 18:55:20 2004 UTC (15 years ago) by olson
Changes since 1.183: +39 -2 lines
Diff to previous 1.183
Add subsystem_roles() method.
Add status callback to translate_pegs.
Remove setting of sticky bit in verify_dir.
Revision 1.183 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 10 22:10:22 2004 UTC (15 years ago) by olson
Changes since 1.182: +46 -0 lines
Diff to previous 1.182
add higher-level construct support
Revision 1.182 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Nov 5 14:57:59 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.181: +0 -1 lines
Diff to previous 1.181
untested changes to extract_genomes - copy-all-but in Global
Revision 1.181 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Nov 4 18:27:29 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.180: +4 -1 lines
Diff to previous 1.180
allow external IDs on subsystem displays
Revision 1.180 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 3 17:46:17 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.179: +7 -0 lines
Diff to previous 1.179
add is_complete function to FIG.pm
Revision 1.179 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Nov 2 14:45:31 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.178: +81 -1 lines
Diff to previous 1.178
fix bug in subsys.cgi and add Literature to Global
Revision 1.178 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 25 20:59:34 2004 UTC (15 years, 1 month ago) by redwards
Changes since 1.177: +8 -0 lines
Diff to previous 1.177
Adding  some pod
Revision 1.177 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Oct 23 21:41:38 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.176: +1 -1 lines
Diff to previous 1.176
stupid error in FIG.pm
Revision 1.176 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Oct 23 19:58:28 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.175: +2 -2 lines
Diff to previous 1.175
fix bound in find_role_in_org
Revision 1.175 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Oct 22 19:30:37 2004 UTC (15 years, 1 month ago) by heiko
Changes since 1.174: +23 -0 lines
Diff to previous 1.174
added function
all_features_detailed
will return fig_id, location, type as array
Revision 1.174 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Oct 22 16:55:42 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.173: +7 -7 lines
Diff to previous 1.173
fill_in_cell for Heiko
Revision 1.173 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Oct 17 16:40:13 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.172: +9 -7 lines
Diff to previous 1.172
added homologs_in_clusters.cgi
Revision 1.172 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Oct 17 00:05:17 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.171: +4 -0 lines
Diff to previous 1.171
fix to by_alias
Revision 1.171 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Oct 17 00:02:34 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.170: +21 -6 lines
Diff to previous 1.170
fixes to UniProt IDs on chromosomal_clusters.cgi
Revision 1.170 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Oct 16 20:42:28 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.169: +22 -2 lines
Diff to previous 1.169
fixes to generalize chromosomal_clusters.cgi for UniProt
Revision 1.169 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Oct 15 17:04:09 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.168: +97 -48 lines
Diff to previous 1.168
peg links generalized to fid links
Revision 1.168 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Oct 15 00:38:11 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.167: +15 -4 lines
Diff to previous 1.167
fixes to subsystem code
Revision 1.167 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 11 23:55:40 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.166: +1 -0 lines
Diff to previous 1.166
remove extra EOLs on changed locations
Revision 1.166 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 11 21:38:58 2004 UTC (15 years, 1 month ago) by overbeek
Changes since 1.165: +7 -2 lines
Diff to previous 1.165
fixes to change_location_of_feature
Revision 1.165 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 11 18:46:45 2004 UTC (15 years, 1 month ago) by olson
Changes since 1.164: +10 -44 lines
Diff to previous 1.164
More fixes for sprout support.
Revision 1.164 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Oct 8 22:04:48 2004 UTC (15 years, 1 month ago) by redwards
Changes since 1.163: +1 -1 lines
Diff to previous 1.163
Added number of contigs to menu
Revision 1.163 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Oct 5 22:06:28 2004 UTC (15 years, 2 months ago) by olson
Changes since 1.162: +55 -0 lines
Diff to previous 1.162
more DAS fixes
Revision 1.162 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Oct 4 15:56:10 2004 UTC (15 years, 2 months ago) by olson
Changes since 1.161: +29 -0 lines
Diff to previous 1.161
Changes for DAS integration
Revision 1.161 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Oct 1 19:48:37 2004 UTC (15 years, 2 months ago) by overbeek
Changes since 1.160: +5 -5 lines
Diff to previous 1.160
minor fixes to exporting sets
Revision 1.160 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 24 20:27:22 2004 UTC (15 years, 2 months ago) by olson
Changes since 1.159: +20 -1 lines
Diff to previous 1.159
doc fix
Revision 1.159 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 24 18:58:42 2004 UTC (15 years, 2 months ago) by olson
Changes since 1.158: +7 -4 lines
Diff to previous 1.158
Possible fix for beg_of and contig_of
More p2p stuff
Revision 1.158 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 24 18:34:32 2004 UTC (15 years, 2 months ago) by olson
Changes since 1.157: +165 -1 lines
Diff to previous 1.157
Some contig manipulation stuff, more p2p stuff.
Revision 1.157 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 23 20:04:04 2004 UTC (15 years, 2 months ago) by redwards
Changes since 1.156: +16 -2 lines
Diff to previous 1.156
$fig->adjacent_genes was not returning adjacent genes
Revision 1.156 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 22 19:32:29 2004 UTC (15 years, 2 months ago) by olson
Changes since 1.155: +0 -2 lines
Diff to previous 1.155
remove print
Revision 1.155 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 22 19:29:51 2004 UTC (15 years, 2 months ago) by olson
Changes since 1.154: +134 -1 lines
Diff to previous 1.154
Mods for P2P update stuff.
Revision 1.154 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Sep 20 21:16:02 2004 UTC (15 years, 2 months ago) by overbeek
Changes since 1.153: +6 -3 lines
Diff to previous 1.153
subsystem_genomes should return just genomes with an operational variant
Revision 1.153 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 16 15:15:57 2004 UTC (15 years, 2 months ago) by olson
Changes since 1.152: +4 -4 lines
Diff to previous 1.152
remove inappropriate setting of g+s bit
Revision 1.152 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 16 04:35:03 2004 UTC (15 years, 2 months ago) by overbeek
Changes since 1.151: +4 -4 lines
Diff to previous 1.151
Fixed errors in POD documentation. -- /gdp
Revision 1.151 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Sep 13 02:12:20 2004 UTC (15 years, 2 months ago) by overbeek
Changes since 1.150: +19 -0 lines
Diff to previous 1.150
add attributes as key-value pairs attached to fids
Revision 1.150 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Sep 11 00:46:49 2004 UTC (15 years, 2 months ago) by golsen
Changes since 1.149: +9 -3 lines
Diff to previous 1.149
Add domain-based selection to genomes function.  Used to generate domain-specfic genome lists.
Revision 1.149 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 9 00:00:09 2004 UTC (15 years, 2 months ago) by overbeek
Changes since 1.148: +0 -1 lines
Diff to previous 1.148
minor fixes
Revision 1.148 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 7 02:54:16 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.147: +17 -2 lines
Diff to previous 1.147
add new subsystem interface
Revision 1.147 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Aug 27 21:55:57 2004 UTC (15 years, 3 months ago) by mkubal
Changes since 1.146: +81 -2 lines
Diff to previous 1.146
added adjacent_genes() and supporting methods
Revision 1.146 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Aug 27 18:32:07 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.145: +14 -0 lines
Diff to previous 1.145
set current user
Revision 1.145 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Aug 24 22:12:17 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.144: +6 -4 lines
Diff to previous 1.144
minor changes to indexing translations
Revision 1.144 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 23 18:58:54 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.143: +1 -1 lines
Diff to previous 1.143
sort sims into the correct order
Revision 1.143 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 23 18:51:34 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.142: +3 -3 lines
Diff to previous 1.142
fix evil bug in index searches
Revision 1.142 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 23 18:35:51 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.141: +17 -2 lines
Diff to previous 1.141
sort sims by bit score
Revision 1.141 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 23 03:34:32 2004 UTC (15 years, 3 months ago) by golsen
Changes since 1.140: +200 -2 lines
Diff to previous 1.140
Fix a typo in annotations_made and start adding infrastructure to fix genes_in_region issues
Revision 1.140 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Aug 22 21:36:42 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.139: +1 -0 lines
Diff to previous 1.139
have function_of append to end of lines
Revision 1.139 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Aug 20 17:37:58 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.138: +70 -89 lines
Diff to previous 1.138
update feature alterations
Revision 1.138 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Aug 20 00:42:54 2004 UTC (15 years, 3 months ago) by golsen
Changes since 1.137: +8 -8 lines
Diff to previous 1.137
Fixed major error in org_of
Revision 1.137 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Aug 19 23:45:58 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.136: +31 -0 lines
Diff to previous 1.136
handle changes to feature locations
Revision 1.136 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Aug 18 15:46:51 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.135: +179 -22 lines
Diff to previous 1.135
add abilities to add, delete and update features
Revision 1.135 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 16 22:10:55 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.134: +160 -60 lines
Diff to previous 1.134
straighten out FIG.pm
Revision 1.134 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Aug 13 14:04:20 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.133: +126 -0 lines
Diff to previous 1.133
interface for Bielefeld in FIG.pm
Revision 1.133 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Aug 12 11:39:44 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.132: +1 -1 lines
Diff to previous 1.132
fix errors relating to read_annotations
Revision 1.132 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 9 13:36:18 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.131: +2 -2 lines
Diff to previous 1.131
major fix in read_annotations in FIG.pm
Revision 1.131 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Aug 7 18:48:39 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.130: +1 -1 lines
Diff to previous 1.130
fixes to aliases_of
Revision 1.130 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 2 20:02:29 2004 UTC (15 years, 4 months ago) by golsen
Changes since 1.129: +81 -0 lines
Diff to previous 1.129
Colorize organisms by domain in similarities list.  Changes protein.cgi and FIG.pm
Revision 1.129 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Aug 1 11:50:25 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.128: +1 -2 lines
Diff to previous 1.128
fix order on genes returned in a region
Revision 1.128 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jul 25 21:48:15 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.127: +3 -1 lines
Diff to previous 1.127
sort links
Revision 1.127 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jul 18 22:58:36 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.126: +41 -6 lines
Diff to previous 1.126
handle bug that lost notes for subsystems
Revision 1.126 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 16 21:58:03 2004 UTC (15 years, 4 months ago) by gdpusch
Changes since 1.125: +19 -5 lines
Diff to previous 1.125
Added out-of-bounds checks to &extract_seq(), plus debugging information for loci whose sequences could not be extracted.
Revision 1.125 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 16 20:41:26 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.124: +4 -0 lines
Diff to previous 1.124
updates to ssa2.cgi and warnings when assignments fail
Revision 1.124 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jul 12 21:14:53 2004 UTC (15 years, 4 months ago) by olson
Changes since 1.123: +6 -0 lines
Diff to previous 1.123
Add "umask 0" to fig.pm to ensure all new files are world writable.
Revision 1.123 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jul 1 21:17:53 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.122: +282 -45 lines
Diff to previous 1.122
More sim/askfor/pool stuff.
Make fig load_all show progress.
Fix run_in_background to do the right thing with an open db handle.
Revision 1.122 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 28 20:11:14 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.121: +42 -2 lines
Diff to previous 1.121
Add assignments_made_for_protein
expand some code for readability.
Revision 1.121 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jun 27 22:49:49 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.120: +9 -1 lines
Diff to previous 1.120
handle names of subsystems just a bit better
Revision 1.120 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 23 21:33:43 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.119: +58 -10 lines
Diff to previous 1.119
Add assignments_made_full, which returns the date and id of person who made the assignment.
assignments_made now just maps the result of assignments_made.
Add some comments.
Revision 1.119 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 16 16:52:10 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.118: +1 -0 lines
Diff to previous 1.118
Modifications to fix & finish up the automated subsystem extension.
Revision 1.118 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 16 14:25:36 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.117: +1 -0 lines
Diff to previous 1.117
New map support.
Revision 1.117 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 16 14:04:40 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.116: +98 -0 lines
Diff to previous 1.116
add background job support.
Revision 1.116 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 14 22:04:24 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.115: +96 -0 lines
Diff to previous 1.115
Add background job support
Revision 1.115 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 10 14:00:36 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.114: +5 -5 lines
Diff to previous 1.114
Add scalar decl to is_bacterial and friends.
Revision 1.114 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 10 13:39:55 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.113: +30 -0 lines
Diff to previous 1.113
add more funcs for tutorials
Revision 1.113 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 8 20:26:23 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.112: +159 -4 lines
Diff to previous 1.112
add some scalar annotations; add find_role_in_org
Revision 1.112 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 8 17:19:43 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.111: +16 -2 lines
Diff to previous 1.111
Guard the rquire of figrpc in case we don't have the necessary modules installed for it.
Revision 1.111 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 8 15:02:14 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.110: +70 -14 lines
Diff to previous 1.110
Add capability for :scalar :list :remote annotations to FIG interface. This works with
modules that are declared as subclasses of FIGAttributes.
Revision 1.110 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 3 20:58:04 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.109: +1 -1 lines
Diff to previous 1.109
reorder load of databases just slightly
Revision 1.109 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 3 08:12:44 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.108: +1 -1 lines
Diff to previous 1.108
Fixed typo in pod-documentation
Revision 1.108 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 2 09:45:16 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.107: +30 -29 lines
Diff to previous 1.107
Added check for "defined" status of filehandle reads from <SSA>; removed various "masking" redefinitions of "my" variables.
Revision 1.107 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 2 09:23:35 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.106: +46 -16 lines
Diff to previous 1.106
Fixed typos in various $fig->genome_*() accessor functions.
Revision 1.106 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 1 20:45:39 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.105: +1 -1 lines
Diff to previous 1.105
fix typo.
Revision 1.105 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 1 20:40:55 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.104: +2 -2 lines
Diff to previous 1.104
Add $force_load argument to get_subsystem; results in the discarding
of the cached subsystem if there is one.
Revision 1.104 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 1 20:21:44 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.103: +20 -0 lines
Diff to previous 1.103
add subsystems_for_peg
Revision 1.103 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 1 19:06:17 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.102: +3 -2 lines
Diff to previous 1.102
fix the call to figrpc
Revision 1.102 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 1 19:02:37 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.101: +13 -0 lines
Diff to previous 1.101
added redirect in FIG constructor to create a FIGrpc if the FIG_URL environment variable is set
Revision 1.101 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 1 00:45:38 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.100: +5 -2 lines
Diff to previous 1.100
make bbhs sensitive to lengths of match - watch out for fused proteins
Revision 1.100 - (view) (download) (as text) (annotate) - [select for diffs]
Sun May 30 15:04:26 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.99: +21 -9 lines
Diff to previous 1.99
precomputed BBHs
Revision 1.99 - (view) (download) (as text) (annotate) - [select for diffs]
Sat May 29 14:08:58 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.98: +1 -1 lines
Diff to previous 1.98
Revision 1.98 - (view) (download) (as text) (annotate) - [select for diffs]
Fri May 28 19:27:00 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.97: +21 -5 lines
Diff to previous 1.97
attempt to change FIG.pm to keep mac-1 up
Thu May 27 18:22:11 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.96: +0 -1 lines
Diff to previous 1.96
doh, had left a debug print in there
Wed May 26 22:34:17 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.95: +19 -0 lines
Diff to previous 1.95
add genome_and_peg_of
Mon May 24 22:02:47 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.94: +10 -3 lines
Diff to previous 1.94
Factor out the subsystem caching.
Mon May 24 21:59:32 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.93: +8 -1 lines
Diff to previous 1.93
cache subsystem objects, since they can be expensive to create.
Mon May 24 21:55:18 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.92: +196 -34 lines
Diff to previous 1.92
Beginning of sim queueing stuff.
First implementation of Subsystem object, with FIG::peg_in_subsystem_cell
implemented in terms of it.
Mon May 24 21:14:16 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.91: +60 -3 lines
Diff to previous 1.91
Changed name of genome-size access method to \&genome_szdna($genome_id) to match the SQL keyword; added \&genome_pegs($genome) and \&genome_rnas($genome) to return number of PEGs and RNAs, resp.
Mon May 24 21:03:39 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.90: +28 -0 lines
Diff to previous 1.90
Added access method \&genome_size($genome_id) to return the number of base-pairs in an organism\'s contig files.
Mon May 24 19:32:36 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.89: +47 -0 lines
Diff to previous 1.89
add file_head and file_read
Sat May 22 11:43:00 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.88: +6 -0 lines
Diff to previous 1.88
fix error in tutorial
Fri May 21 18:05:55 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.87: +6 -2 lines
Diff to previous 1.87
fixes to similarities
Thu May 20 12:26:47 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.86: +14 -2 lines
Diff to previous 1.86
make aliases include external aliases
Wed May 19 15:54:10 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.85: +3 -0 lines
Diff to previous 1.85
allow comma-separated contiguous regions in dna_seq argument list
Wed May 19 14:15:57 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.84: +25 -0 lines
Diff to previous 1.84
add all_contigs
Wed May 19 13:17:39 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.83: +25 -9 lines
Diff to previous 1.83
fixes on memory leak and genome version
Tue May 18 00:44:54 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.82: +1 -1 lines
Diff to previous 1.82
set max open files to 50
Mon May 17 09:22:50 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.81: +91 -8 lines
Diff to previous 1.81
support addition of links to pegs
Fri May 14 18:06:51 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.80: +41 -1 lines
Diff to previous 1.80
fixed up links
Thu May 13 20:59:56 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.79: +1 -2 lines
Diff to previous 1.79
fix add_genome
Tue May 4 16:27:23 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.78: +43 -3 lines
Diff to previous 1.78
more protection around the code that pokes at the clearing house, in case xmlrpc libs are missing
Mon May 3 17:16:50 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.77: +11 -0 lines
Diff to previous 1.77
Add comment.
Sat May 1 02:56:38 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.76: +3 -2 lines
Diff to previous 1.76
Comment out import of Clearinghouse until we get the env updated.
Thu Apr 29 16:41:16 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.75: +9 -0 lines
Diff to previous 1.75
tools for query
Wed Apr 28 21:59:32 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.74: +184 -0 lines
Diff to previous 1.74
Clearinghouse publishing stuff
Wed Apr 28 04:34:52 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.73: +4 -1 lines
Diff to previous 1.73
fix to definition of bbh
Tue Apr 27 15:41:28 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.72: +22 -0 lines
Diff to previous 1.72
basic query tools
Sat Apr 24 23:27:05 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.71: +4 -3 lines
Diff to previous 1.71
make sure that external_calls produces one function for each peg
Sat Apr 24 15:02:08 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.70: +34 -6 lines
Diff to previous 1.70
tools for McCune to build expert automated assignments
Fri Apr 23 21:51:15 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.69: +1 -0 lines
Diff to previous 1.69
make load_all build blast dbs for fig proteins
Fri Apr 23 21:49:02 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.68: +1 -1 lines
Diff to previous 1.68
fixes to index.cgi to blast against all complete
Fri Apr 23 17:23:40 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.67: +2 -2 lines
Diff to previous 1.67
fixes to best_candidates
Fri Apr 23 16:59:40 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.66: +9 -5 lines
Diff to previous 1.66
fixes to best_bbh_candidates
Mon Apr 19 11:36:39 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.65: +4 -2 lines
Diff to previous 1.65
fix a bad bug in assignment permissions
Fri Apr 9 15:26:05 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.64: +17 -3 lines
Diff to previous 1.64
pass back more detailed data for candidates for a role
Fri Apr 9 14:55:36 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.63: +85 -0 lines
Diff to previous 1.63
more intelligent candidates for function
Thu Apr 8 11:49:33 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.62: +11 -0 lines
Diff to previous 1.62
fixes in auto assignments
Thu Apr 1 22:58:44 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.61: +8 -0 lines
Diff to previous 1.61
allow p2p to send me epoch dates, rather than readable dates
Thu Apr 1 22:10:34 2004 UTC (15 years, 8 months ago) by overbeek
Diff to previous 1.60
turn off warning messages for translation failures when translating PEG ids
Thu Apr 1 22:07:31 2004 UTC (15 years, 8 months ago) by disz
Changes since 1.59: +4 -4 lines
Diff to previous 1.59
More P2P fixes.
Add setgid to the mkdir/chmod's.
Thu Apr 1 14:54:57 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.58: +66 -0 lines
Diff to previous 1.58
fixes to candidates for a role
Wed Mar 31 19:20:24 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.57: +11 -1 lines
Diff to previous 1.57
p2p for updating release
Wed Mar 31 18:39:15 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.56: +3 -3 lines
Diff to previous 1.56
p2p changes
Wed Mar 31 16:32:22 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.55: +52 -0 lines
Diff to previous 1.55
attempt to fix package/install for p2p
Wed Mar 31 11:14:47 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.54: +148 -0 lines
Diff to previous 1.54
move PEG translation into FIG.pm
Mon Mar 29 23:13:14 2004 UTC (15 years, 8 months ago) by mkubal
Changes since 1.53: +2 -2 lines
Diff to previous 1.53
removes ## markers in FIG.pm
Mon Mar 29 23:12:40 2004 UTC (15 years, 8 months ago) by mkubal
Changes since 1.52: +7 -104 lines
Diff to previous 1.52
removes ## markers in FIG.pm and fixed Blast.pm
Fri Mar 26 21:38:38 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.51: +18 -0 lines
Diff to previous 1.51
Make get_local_hostname check for a FIGdisk/config/hostname file and use
that as the local hostname if present.
Fri Mar 26 13:01:46 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.50: +11 -2 lines
Diff to previous 1.50
better peg mapping when importing spreadsheets
Thu Mar 25 17:10:50 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.49: +11 -0 lines
Diff to previous 1.49
includes errors
Thu Mar 25 13:48:27 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.48: +3 -1 lines
Diff to previous 1.48
improvements on importing subsystems
Wed Mar 24 00:05:40 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.47: +1 -1 lines
Diff to previous 1.47
export subsystems stuff
Tue Mar 23 21:54:03 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.46: +7 -1 lines
Diff to previous 1.46
Broke a semicolon-chained set of commands in &delete_genomes() into separate &run() invocations, so that if any of them fail, the delete operation will abort. -- /gdp
Mon Mar 22 02:33:57 2004 UTC (15 years, 8 months ago) by gdpusch
Changes since 1.45: +1 -1 lines
Diff to previous 1.45
Fixed failure to declare two variables in routine &read_fasta_record(). -- /gdp
Mon Mar 22 01:51:30 2004 UTC (15 years, 8 months ago) by gdpusch
Changes since 1.44: +58 -1 lines
Diff to previous 1.44
Added routine &read_fasta_record(). -- /gdp
Fri Mar 19 21:58:31 2004 UTC (15 years, 8 months ago) by golsen
Changes since 1.43: +24 -13 lines
Diff to previous 1.43
Relative base address support and cgi_url() based on current http request
Fri Mar 19 18:45:36 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.42: +39 -22 lines
Diff to previous 1.42
fixes to coupling and protein.cgi
Thu Mar 18 16:02:32 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.41: +19 -0 lines
Diff to previous 1.41
add versions to spreadsheets
Thu Mar 18 13:16:40 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.40: +1 -1 lines
Diff to previous 1.40
exchangable flags on spreadsheet
Wed Mar 17 20:18:22 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.39: +105 -6 lines
Diff to previous 1.39
for Gordon and Mike
Wed Mar 17 18:17:34 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.38: +107 -0 lines
Diff to previous 1.38
basic export of subsystems stuff
Mon Mar 15 23:06:47 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.37: +33 -0 lines
Diff to previous 1.37
Add get_seed_id()
Mon Mar 15 04:37:50 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.36: +2 -4 lines
Diff to previous 1.36
new spreadsheet
Sun Mar 14 03:46:16 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.35: +298 -188 lines
Diff to previous 1.35
fixes
Tue Mar 9 23:19:23 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.34: +97 -0 lines
Diff to previous 1.34
fixed distances and spreadsheet
Fri Mar 5 22:17:16 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.33: +25 -0 lines
Diff to previous 1.33
support gi and NP numbers for access to fig IDs
Wed Mar 3 14:56:43 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.32: +48 -1 lines
Diff to previous 1.32
add merged annotations
Wed Mar 3 12:49:23 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.31: +4 -2 lines
Diff to previous 1.31
fixes from DOE meeting
Thu Feb 19 12:55:35 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.30: +1 -1 lines
Diff to previous 1.30
fix bug due to change in sims
Tue Feb 17 22:23:36 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.29: +9 -5 lines
Diff to previous 1.29
preserve translation through similarities
Sun Feb 15 17:12:54 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.28: +7 -4 lines
Diff to previous 1.28
added Gary Olsen changes
Tue Feb 10 22:35:57 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.27: +19 -1 lines
Diff to previous 1.27
in get_local_hostname, ensure that we get a FQDN. If we don't, just bail and
use our IP address.
Tue Feb 3 16:45:57 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.26: +9 -0 lines
Diff to previous 1.26
minor fixes
Mon Jan 26 22:51:32 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.25: +12 -4 lines
fixes
Wed Jan 21 18:27:29 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.24: +1 -0 lines
from the Penn trip
Fri Jan 16 19:37:40 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.23: +2 -2 lines
chop delimiter off annotations
Wed Jan 14 20:20:32 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.22: +9 -99 lines
synch up Ross
Thu Jan 8 16:31:59 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.21: +8 -0 lines
handle loops in translation
Wed Jan 7 03:34:13 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.20: +9 -0 lines
make Assignments files have readable names
Tue Jan 6 23:08:26 2004 UTC (15 years, 11 months ago) by overbeek
fix in extract_genomes
Tue Jan 6 18:14:48 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.18: +14 -4 lines
fix stick behavior for checked sims
Mon Jan 5 12:26:58 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.17: +2 -1 lines
minor bugs
Sat Jan 3 14:13:48 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.16: +41 -1 lines
fix P2P to use get_assignments
Sat Jan 3 06:03:43 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.15: +25 -20 lines
changes to annotations to allow extraction of assignments
Tue Dec 30 05:21:24 2003 UTC (15 years, 11 months ago) by overbeek
fix order of database loads
Mon Dec 29 02:22:37 2003 UTC (15 years, 11 months ago) by overbeek
Changes since 1.13: +17 -12 lines
numerous performance issues
Sun Dec 28 17:11:29 2003 UTC (15 years, 11 months ago) by overbeek
Changes since 1.12: +55 -18 lines
cleanup issues relating to large numbers of partial genomes
Tue Dec 23 22:38:31 2003 UTC (15 years, 11 months ago) by overbeek
make plugging URLs more robust
Tue Dec 23 22:29:51 2003 UTC (15 years, 11 months ago) by olson
Changes since 1.10: +5 -5 lines
remove prints
Tue Dec 23 22:28:10 2003 UTC (15 years, 11 months ago) by olson
Changes since 1.9: +207 -0 lines
Add IP-determination logic.
Mon Dec 22 01:24:22 2003 UTC (15 years, 11 months ago) by overbeek
Changes since 1.8: +14 -5 lines
add pins and clusters properly
Sun Dec 21 01:20:59 2003 UTC (15 years, 11 months ago) by overbeek
Changes since 1.7: +0 -1 lines
allow multiple sims files in update_sims
Sat Dec 20 21:08:43 2003 UTC (15 years, 11 months ago) by overbeek
Changes since 1.6: +26 -3 lines
fixed issues relating to addition/deletion of genomes
Fri Dec 19 20:09:34 2003 UTC (15 years, 11 months ago) by overbeek
Changes since 1.5: +0 -18 lines
get rid of set_urls, since it will not work anymore
Fri Dec 5 14:31:23 2003 UTC (16 years ago) by overbeek
CVS Tags: delong-01, delong-02
fix permissions on added genome
Thu Dec 4 21:49:02 2003 UTC (16 years ago) by overbeek
Changes since 1.3: +6 -2 lines
fix bug in function translation
Wed Dec 3 21:24:31 2003 UTC (16 years ago) by overbeek
Changes since 1.2: +4 -3 lines
Wed Dec 3 19:39:29 2003 UTC (16 years ago) by efrank
Changes since 1.1: +25 -5 lines
fixed a bunch of changes
Mon Dec 1 16:54:26 2003 UTC (16 years ago) by efrank
Branch point for: initial
