[Bio] / FigKernelPackages / FIG.pm Repository:
Diff of /FigKernelPackages/FIG.pm
revision 1.419, Thu Jan 12 23:48:15 2006 UTC revision 1.420, Fri Jan 13 06:54:49 2006 UTC
# Line 28  Line 28
28  use FileHandle;  use FileHandle;
29  use File::Copy;  use File::Copy;
30  use SOAP::Lite;  use SOAP::Lite;
31    use File::Path;
32
33  use DBrtns;  use DBrtns;
34  use Sim;  use Sim;
# Line 2909  Line 2910
2910
2911          #          #
2912          # If $fname is relative, prepend the base of the fig_disk.          # If $fname is relative, prepend the base of the fig_disk.
2913            # (Updated to use PERL's system-independent filename utilities.
2914          #          #
2915
2916          if ($fname !~ m,^/,)          $fname = File::Spec->rel2abs($fname, $FIG_Config::fig_disk);
             $fname = "$FIG_Config::fig_disk/$fname";
2917
2918          $fcache->{$fileno} = $fname;          $fcache->{$fileno} = $fname;
2919          return $fname;          return $fname;
Legend:
Removed from v.1.419
changed lines
  Added in v.1.420
