[Bio] / FigKernelPackages / FIG.pm Repository:
Diff of /FigKernelPackages/FIG.pm
revision 1.387, Thu Oct 27 16:20:34 2005 UTC revision 1.388, Fri Oct 28 16:03:12 2005 UTC
# Line 2522  Line 2522
2522      (system($cmd) == 0) || Confess("FAILED: $cmd");      (system($cmd) == 0) || Confess("FAILED: $cmd");
2523  }  }
2524
2525    =head3 run_gathering_output
2526
2527    C<< FIG::run_gathering_output($cmd, @args); >>
2528
2529    or
2530
2531    C<< $fig->run_gathering_output($cmd, @args); >>
2532
2533    Run a command, gathering the output. This is similar to the backtick
2534    operator, but it does not invoke the shell. Note that the argument list
2535    must be explicitly passed one command line argument per argument to
2536    run_gathering_output.
2537
2538    If the command fails, the error will be traced.
2539
2540    =cut
2541
2542    sub run_gathering_output {
2543        shift if UNIVERSAL::isa($_[0],__PACKAGE__);
2544        my($cmd, @args) = @_;
2545
2546        #
2547        # Run the command in a safe fork-with-pipe/exec.
2548        #
2549
2550        my $pid = open(PROC_READ, "-|");
2551
2552        if ($pid == 0)
2553        {
2554            exec { $cmd } $cmd, @args;
2555            die "could not execute $cmd @args: $!\n";
2556        }
2557
2558        if (wantarray)
2559        {
2560            my @out;
2561            while (<PROC_READ>)
2562            {
2563                push(@out, $_);
2564            }
2565            if (!close(PROC_READ))
2566            {
2567                Confess("FAILED: $cmd @args with error return $?");
2568            }
2569            return @out;
2570        }
2571        else
2572        {
2573            my $out = '';
2574
2575            while (<PROC_READ>)
2576            {
2577                $out .= $_;
2578            }
2579            if (!close(PROC_READ))
2580            {
2581                Confess("FAILED: $cmd @args with error return $?");
2582            }
2583            return $out;
2584        }
2585    }
2586
2587  =head3 augment_path  =head3 augment_path
2588
2589  C<< FIG::augment_path($dirName); >>  C<< FIG::augment_path($dirName); >>
Legend:
Removed from v.1.387
changed lines
  Added in v.1.388
