[Bio] / FigKernelPackages / FIG.pm Repository:
Diff of /FigKernelPackages/FIG.pm
revision 1.378, Thu Oct 13 20:13:48 2005 UTC revision 1.379, Thu Oct 20 10:22:04 2005 UTC
# Line 5876  Line 5876
5876
5877  =head3 function_of  =head3 function_of
5878
5879  usage: @functions = $fig->function_of($peg)  OR  C<< my $function = $fig->function_of($id, $user); >>
        $function  = $fig->function_of($peg,$user)
5880
5881  In a list context, you get back a list of 2-tuples.  Each 2-tuple is of the  or
5882  form [MadeBy,Function].
5883    C<< my @functions = $fig->function_of($id); >>
5884
5885    In a scalar context, returns the most recently-determined functional
5886    assignment of a specified feature by a particular user. In a list
5887    context, returns a list of 2-tuples, each consisting of a user ID
5888    followed by a functional assighment by that user. In this case,
5889    the list contains all the functional assignments for the feature.
5890
5891    =over 4
5892
5893    =item id
5894
5895    ID of the relevant feature.
5896
5897    =item user
5898
5899  In a scalar context,  ID of the user whose assignment is desired (scalar context only)
5900
5901      1. user is "master" if not specified  =item RETURN
5902      2. function returned is the user's, if one exists; otherwise, master's, if one exists
5903    Returns the most recent functional assignment by the given user in scalar
5904    context, and a list of functional assignments in list context. Each assignment
5905    in the list context is a 2-tuple of the form [$user, $assignment].
5906
5907  In a scalar context, you get just the function.  =back
5908
5909  =cut  =cut
5910
# Line 7833  Line 7850
7850
7851      # build the SQL statement depending on what we have      # build the SQL statement depending on what we have
7852      my @col=('fid','tag','val','url');      my @col=('fid','tag','val','url');
7853      my $select = "SELECT fid,tag,val,url FROM attribute ";      my $select = "SELECT DISTINCT fid,tag,val,url FROM attribute ";
7854      my $first=1;      my $first=1;
7855      for (my $i=0; $i<=3; $i++)      for (my $i=0; $i<=3; $i++)
7856      {      {
# Line 9068  Line 9085
9085
9086  =head3 all_compounds  =head3 all_compounds
9087
9088  usage: @compounds = $fig->all_compounds  C<< my @compounds = $fig->all_compounds(); >>
9089
9090  Returns a list containing all of the KEGG compounds.  Return a list containing all of the KEGG compounds.
9091
9092  =cut  =cut
9093
# Line 9088  Line 9105
9105
9106  =head3 names_of_compound  =head3 names_of_compound
9107
9108  usage: @names = $fig->names_of_compound($cid)  C<< my @names = $fig->names_of_compound($cid); >>
9109
9110  Returns a list containing all of the names assigned to the KEGG compounds.  The list  Returns a list containing all of the names assigned to the specified KEGG compound. The list
9111  will be ordered as given by KEGG.  will be ordered as given by KEGG.
9112
9113    =over 4
9114
9115    =item cid
9116
9117    ID of the desired compound.
9118
9119    =item RETURN
9120
9121    Returns a list of names for the specified compound.
9122
9123    =back
9124
9125  =cut  =cut
9126
9127  sub names_of_compound {  sub names_of_compound {
# Line 9109  Line 9138
9138
9139  =head3 comp2react  =head3 comp2react
9140
9141  usage: @rids = $fig->comp2react($cid)  C<< my @rids = $fig->comp2react($cid); >>
9142
9143  Returns a list containing all of the reaction IDs for reactions that take $cid  Returns a list containing all of the reaction IDs for reactions that take $cid
9144  as either a substrate or a product.  as either a substrate or a product.
# Line 9130  Line 9159
9159
9160  =head3 valid_reaction_id  =head3 valid_reaction_id
9161
9162  usage: if ($fig->valid_reaction_id($rid)  { ... }  C<< my $flag = $fig->valid_reaction_id($rid); >>
9163
9164  Returns true iff $rid is a valid reaction ID.  Returns true iff the specified ID is a valid reaction ID.
9165
9166  This will become important as we include non-KEGG reactions  This will become important as we include non-KEGG reactions
9167
9168    =over 4
9169
9170    =item rid
9171
9172    Reaction ID to test.
9173
9174    =item RETURN
9175
9176    Returns TRUE if the reaction ID is in the data store, else FALSE.
9177
9178    =back
9179
9180  =cut  =cut
9181
9182  sub valid_reaction_id  sub valid_reaction_id
# Line 9149  Line 9190
9190
9191  =head3 cas  =head3 cas
9192
9193  usage: $cas = $fig->cas($cid)  C<< my $cas = $fig->cas($cid); >>
9194
9195    Return the Chemical Abstract Service (CAS) ID for the compound, if known.
9196
9197    =over 4
9198
9199    =item cid
9200
9201    ID of the compound whose CAS ID is desired.
9202
9203    =item RETURN
9204
9205    Returns the CAS ID of the specified compound, or an empty string if the CAS ID
9206    is not known or does not exist.
9207
9208  Returns the CAS ID for the compound, if known.  =back
9209
9210  =cut  =cut
9211
# Line 9169  Line 9223
9223
9224  =head3 cas_to_cid  =head3 cas_to_cid
9225
9226  usage: $cid = $fig->cas_to_cid($cas)  C<< my $cid = $fig->cas_to_cid($cas); >>
9227
9228    Return the compound id (cid), given the Chemical Abstract Service (CAS) ID.
9229
9230    =over 4
9231
9232    =item cas
9233
9234  Returns the compound id (cid), given the CAS ID.  CAS ID of the desired compound.
9235
9236    =item RETURN
9237
9238    Returns the ID of the compound corresponding to the specified CAS ID, or an empty
9239    string if the CAS ID is not in the data store.
9240
9241    =back
9242
9243  =cut  =cut
9244
# Line 9189  Line 9256
9256
9257  =head3 all_reactions  =head3 all_reactions
9258
9259  usage: @rids = $fig->all_reactions  << my @rids = $fig->all_reactions(); >>
9260
9261  Returns a list containing all of the KEGG reaction IDs.  Return a list containing all of the KEGG reaction IDs.
9262
9263  =cut  =cut
9264
# Line 9209  Line 9276
9276
9277  =head3 reversible  =head3 reversible
9278
9279  usage: $rev = $fig->reversible($rid)  C<< my $flag = $fig->reversible($rid); >>
9280
9281  Returns true iff the reactions had a "main direction" designated as "<=>";  Return TRUE if the specified reaction is reversible. A reversible reaction has no main
9282    direction. The connector is symbolized by C<< <=> >> instead of C<< => >>.
9283
9284    =over 4
9285
9286    =item rid
9287
9288    ID of the ralevant reaction.
9289
9290    =item RETURN
9291
9292    Returns TRUE if the specified reaction is reversible, else FALSE. If the reaction
9293    does not exist, returns TRUE.
9294
9295    =back
9296
9297  =cut  =cut
9298
# Line 9229  Line 9310
9310
9311  =head3 reaction2comp  =head3 reaction2comp
9312
9313  usage: @tuples = $fig->reaction2comp($rid,$which)  C<< my @tuples = $fig->reaction2comp($rid, $which); >>
9314
9315  Returns the "substrates" iff $which == 0.  In any event (i.e., whether you ask for substrates  Return the substrates or products for a reaction.  In any event (i.e.,
9316  or products), you get back a list of 3-tuples.  Each 3-tuple will contain  whether you ask for substrates or products), you get back a list of
9317    3-tuples.  Each 3-tuple will contain
9318
9319      [$cid,$stoich,$main]      [$cid,$stoich,$main]
9320
9321  Stoichiometry is normally numeric, but can be things like "n" or "(n+1)".  Stoichiometry indicates how many copies of the compound participate in
9322    the reaction. It is normally numeric, but can be things like "n" or "(n+1)".
9323  $main is 1 iff the compound is considered "main" or "connectable".  $main is 1 iff the compound is considered "main" or "connectable".
9324
9325    =over 4
9326
9327    =item rid
9328
9329    ID of the raction whose compounds are desired.
9330
9331    =item which
9332
9333    TRUE if the products (right side) should be returned, FALSE if the substrates
9334    (left side) should be returned.
9335
9336    =item RETURN
9337
9338    Returns a list of 3-tuples. Each tuple contains the ID of a compound, its
9339    stoichiometry, and a flag that is TRUE if the compound is one of the main
9340    participants in the reaction.
9341
9342    =back
9343
9344  =cut  =cut
9345
9346  sub reaction2comp {  sub reaction2comp {
# Line 9255  Line 9357
9357
9358  =head3 catalyzed_by  =head3 catalyzed_by
9359
9360  usage: @ecs = $fig->catalyzed_by($rid)  C<< my @ecs = $fig->catalyzed_by($rid); >>
9361
9362  Returns the ECs that are reputed to catalyze the reaction.  Note that we are currently  Return the ECs (roles) that are reputed to catalyze the reaction.  Note that we are currently
9363  just returning the ECs that KEGG gives.  We need to handle the incompletely specified forms  just returning the ECs that KEGG gives.  We need to handle the incompletely specified forms
9364  (e.g., 1.1.1.-), but we do not do it yet.  (e.g., 1.1.1.-), but we do not do it yet.
9365
9366    =over 4
9367
9368    =item rid
9369
9370    ID of the reaction whose catalyzing roles are desired.
9371
9372    =item RETURN
9373
9374    Returns the IDs of the roles that catalyze the reaction.
9375
9376    =back
9377
9378  =cut  =cut
9379
9380  sub catalyzed_by {  sub catalyzed_by {
Legend:
Removed from v.1.378
changed lines
  Added in v.1.379
