[Bio] / FigKernelPackages / FFserver.pm Repository:
Log of /FigKernelPackages/FFserver.pm
Thu Dec 17 20:48:21 2009 UTC (9 years, 11 months ago) by parrello
Changes since 1.22: +0 -4 lines
Diff to previous 1.22
Removed from the SAS distribution.
Mon Dec 7 21:11:52 2009 UTC (10 years ago) by parrello
Changes since 1.21: +0 -112 lines
Diff to previous 1.21
Deleted obsolete methods.
Mon Nov 16 20:05:41 2009 UTC (10 years ago) by disz
Changes since 1.20: +30 -30 lines
Diff to previous 1.20
Removed should_be_member
Thu Oct 29 18:26:59 2009 UTC (10 years, 1 month ago) by parrello
Changes since 1.19: +478 -38 lines
Diff to previous 1.19
Final server updates.
Fri Aug 21 21:58:08 2009 UTC (10 years, 3 months ago) by olson
CVS Tags: rast_rel_2009_0925
Diff to previous 1.18
increase request size in non-blast case so we don't drown in overhead.
Mon Jul 20 21:48:52 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.17: +31 -0 lines
Diff to previous 1.17
Add find_rnas
Wed Jul 8 20:36:20 2009 UTC (10 years, 5 months ago) by olson
CVS Tags: rast_rel_2009_07_09
Diff to previous 1.16
fix call_genes
Wed Jul 1 17:43:53 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.15: +35 -1 lines
add server-based call_genes
Mon Jun 29 16:33:40 2009 UTC (10 years, 5 months ago) by olson
some protocol changes.
Fri Jun 19 17:30:02 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.13: +35 -3 lines
server fixes
Thu Jun 4 21:23:01 2009 UTC (10 years, 6 months ago) by olson
Changes since 1.12: +31 -12 lines
various fixes, including OTU support
Fri May 22 17:09:20 2009 UTC (10 years, 6 months ago) by olson
Changes since 1.11: +3 -0 lines
fix default parameter setting
Thu May 21 21:53:17 2009 UTC (10 years, 6 months ago) by olson
Changes since 1.10: +8 -3 lines
timeout tuning
Thu May 21 21:29:50 2009 UTC (10 years, 6 months ago) by olson
Changes since 1.9: +25 -9 lines
chnanges for new protocol
Wed May 13 20:09:56 2009 UTC (10 years, 7 months ago) by arodri7
CVS Tags: rast_rel_2009_05_18
Changes since 1.8: +48 -0 lines
added FIGfam functions org_of, function_of, seq_of, aliases_of, and more
Wed May 13 16:44:04 2009 UTC (10 years, 7 months ago) by olson
remove debug stmt
Tue May 12 21:16:29 2009 UTC (10 years, 7 months ago) by olson
add status line to dead post error message
Tue May 12 20:17:55 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.5: +6 -0 lines
add families_containing_peg
Mon May 11 20:55:05 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.4: +8 -6 lines
Parameterize assign_functions_to_DNA to add $min_hits (default to 3) and $max_gap (default to 600) arguments.
Fri May 8 17:08:14 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.3: +21 -1 lines
final? changes to the Figfam server code
Thu May 7 22:07:13 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.2: +27 -5 lines
updated figfam clinet code
Thu Apr 30 20:33:41 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.1: +178 -53 lines
more support for stuff
Tue Apr 28 21:03:25 2009 UTC (10 years, 7 months ago) by olson
FF server inteface module
