[Bio] / FigKernelPackages / FFs.pm Repository:
Log of /FigKernelPackages/FFs.pm
Wed Sep 15 21:48:19 2010 UTC (9 years, 5 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, myrast_33, myrast_rel40, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.48: +13 -2 lines
Diff to previous 1.48
Clean up errors.
Wed Jun 16 20:21:50 2010 UTC (9 years, 8 months ago) by olson
CVS Tags: rast_rel_2010_0827
Changes since 1.47: +88 -757 lines
Diff to previous 1.47
Major update to figfams code. Remove old FigFam/FigFams modules that were tied to the
original decision procedure; update FF/FFs to use the Kmer-based stuff. Add new berkeley
db table processing routines to SeedUtils.
Tue Jan 26 10:34:51 2010 UTC (10 years, 1 month ago) by bartels
CVS Tags: rast_rel_2010_0526
Changes since 1.46: +11 -0 lines
Diff to previous 1.46
added a function
Thu Jul 9 09:12:10 2009 UTC (10 years, 7 months ago) by paczian
CVS Tags: rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118
Changes since 1.45: +12 -2 lines
Diff to previous 1.45
fixed rast figfam display
Sat Jun 20 21:35:07 2009 UTC (10 years, 8 months ago) by overbeek
Changes since 1.44: +7 -1 lines
Diff to previous 1.44
fixes to support Kmer analysis
Sat Jun 20 05:44:42 2009 UTC (10 years, 8 months ago) by overbeek
Changes since 1.43: +1 -0 lines
Diff to previous 1.43
strip comments on roles
Wed Jun 3 20:18:24 2009 UTC (10 years, 8 months ago) by gdpusch
Changes since 1.42: +5 -2 lines
Diff to previous 1.42
Added confession if new() cannot fetch a new FF.pm object
Wed Jun 3 02:27:08 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.41: +5 -3 lines
Diff to previous 1.41
fixed check for figfam object
Thu May 28 19:51:58 2009 UTC (10 years, 9 months ago) by arodri7
Changes since 1.40: +1 -1 lines
Diff to previous 1.40
fixed a RDONLY bug message, took quotes out
Wed May 27 19:29:08 2009 UTC (10 years, 9 months ago) by arodri7
Changes since 1.39: +170 -2 lines
Diff to previous 1.39
updated tie
Wed May 27 17:00:35 2009 UTC (10 years, 9 months ago) by paczian
Changes since 1.38: +15 -5 lines
Diff to previous 1.38
added FIGfam support for RAST orgs
fixed deleted_fids hash
Wed May 13 17:32:52 2009 UTC (10 years, 9 months ago) by arodri7
CVS Tags: rast_rel_2009_05_18
Changes since 1.37: +2 -169 lines
Diff to previous 1.37
updated non-essential functions
Tue Apr 14 16:43:17 2009 UTC (10 years, 10 months ago) by arodri7
Changes since 1.36: +55 -6 lines
Diff to previous 1.36
updates for release 9 FIGfams
Thu Apr 2 01:07:40 2009 UTC (10 years, 10 months ago) by parrello
Changes since 1.35: +8 -2 lines
Diff to previous 1.35
Changed to allow the caller to pass in a FIG object. Added a destructor to clean a circular reference.
Tue Mar 31 20:33:33 2009 UTC (10 years, 11 months ago) by arodri7
Changes since 1.34: +35 -86 lines
Diff to previous 1.34
added subsystems based figfams function
Wed Mar 4 20:57:20 2009 UTC (10 years, 11 months ago) by arodri7
CVS Tags: rast_rel_2009_03_26
Changes since 1.33: +2 -0 lines
Diff to previous 1.33
update to decision procedures
Wed Mar 4 20:49:18 2009 UTC (10 years, 11 months ago) by arodri7
Changes since 1.32: +6 -3 lines
Diff to previous 1.32
Fri Feb 6 16:33:07 2009 UTC (11 years ago) by arodri7
Changes since 1.31: +5 -6 lines
Diff to previous 1.31
added place_in_family_bulk documentation
Fri Feb 6 16:08:04 2009 UTC (11 years ago) by arodri7
Changes since 1.30: +52 -9 lines
Diff to previous 1.30
Mon Feb 2 17:03:14 2009 UTC (11 years ago) by arodri7
CVS Tags: rast_rel_2009_02_05
Changes since 1.29: +6 -1 lines
Diff to previous 1.29
corrected function related to figfam webpage: division error
Sun Jan 25 17:41:04 2009 UTC (11 years, 1 month ago) by olson
Changes since 1.28: +0 -1 lines
Diff to previous 1.28
revert change
Sun Jan 25 17:34:13 2009 UTC (11 years, 1 month ago) by overbeek
Changes since 1.27: +1 -0 lines
Diff to previous 1.27
make ex_assertions.cgi ignore inactive variants
Mon Jan 19 20:26:23 2009 UTC (11 years, 1 month ago) by parrello
Changes since 1.26: +4 -5 lines
Diff to previous 1.26
Added the path to a blastall call so that it works in NMPDR.
Mon Dec 22 07:08:18 2008 UTC (11 years, 2 months ago) by arodri7
Changes since 1.25: +184 -5 lines
Diff to previous 1.25
made changes to steps in decision procedures to make it faster
Thu Sep 4 15:36:34 2008 UTC (11 years, 5 months ago) by arodri7
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.24: +3 -3 lines
Diff to previous 1.24
corrected errors for merge_figfams
Tue Jul 29 14:25:39 2008 UTC (11 years, 7 months ago) by arodri7
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_08_07
Changes since 1.23: +4 -4 lines
Diff to previous 1.23
added merge figfams functions
Tue Jul 29 14:20:14 2008 UTC (11 years, 7 months ago) by arodri7
Changes since 1.22: +41 -4 lines
Diff to previous 1.22
Fri Jul 18 15:53:34 2008 UTC (11 years, 7 months ago) by paczian
Changes since 1.21: +1 -1 lines
Diff to previous 1.21
corrected type in line 550 ($mergerFF -> $mergeFF)
Fri Jul 18 15:16:40 2008 UTC (11 years, 7 months ago) by arodri7
Changes since 1.20: +47 -1 lines
Diff to previous 1.20
added merge capabilities
Wed Jun 18 20:26:37 2008 UTC (11 years, 8 months ago) by arodri7
CVS Tags: rast_rel_2008_07_21
Changes since 1.19: +4 -4 lines
Diff to previous 1.19
update FIGfams
Wed Jun 18 15:56:42 2008 UTC (11 years, 8 months ago) by arodri7
Changes since 1.18: +161 -0 lines
Diff to previous 1.18
Figfams update
Sun May 25 01:34:07 2008 UTC (11 years, 9 months ago) by overbeek
Diff to previous 1.17
update to get_dlit.cgi
Thu May 8 19:31:28 2008 UTC (11 years, 9 months ago) by arodri7
Changes since 1.16: +21 -0 lines
Diff to previous 1.16
updated and corrected place_in_figfam
Thu May 1 02:54:12 2008 UTC (11 years, 10 months ago) by overbeek
allow filtered connections to PDB from FIGfams
Thu May 1 02:40:50 2008 UTC (11 years, 10 months ago) by overbeek
Changes since 1.14: +22 -0 lines
add connections between FIGfams and structures
Thu Apr 17 21:00:10 2008 UTC (11 years, 10 months ago) by olson
CVS Tags: rast_rel_2008_04_23
Changes since 1.13: +20 -11 lines
RAST installation tweaks.
Sun Apr 13 00:20:59 2008 UTC (11 years, 10 months ago) by overbeek
Changes since 1.12: +4 -2 lines
fixes to FIGfam stuff
Sat Apr 12 17:35:43 2008 UTC (11 years, 10 months ago) by overbeek
we cannot use /tmp anymore, alas
Fri Apr 11 12:00:34 2008 UTC (11 years, 10 months ago) by overbeek
Changes since 1.10: +12 -1 lines
updates to FIGfam quality control
Thu Mar 20 20:20:30 2008 UTC (11 years, 11 months ago) by arodri7
Changes since 1.9: +13 -5 lines
in place_in_figfam at the blastall command I took out the head -n 20 which asks for the top 20 blast results, but we need to look at all results because the right result might be lower than the top 20 lines
Fri Feb 22 00:32:31 2008 UTC (12 years ago) by gdpusch
Changes since 1.8: +5 -3 lines
Fixed collision between filehandle FF and package FF. -- /gdp
Thu Feb 21 16:39:57 2008 UTC (12 years ago) by overbeek
Changes since 1.7: +0 -2 lines
add delete_subsystem and rename_subsystem to FIG.pm
Mon Feb 18 19:28:38 2008 UTC (12 years ago) by arodri7
Changes since 1.6: +54 -49 lines
functions for bulk figfam function added - sub family_functions
Mon Feb 18 13:53:11 2008 UTC (12 years ago) by overbeek
Changes since 1.5: +6 -0 lines
support family_containing_peg in FFs.pm
Fri Feb 8 16:09:22 2008 UTC (12 years ago) by overbeek
Changes since 1.4: +48 -33 lines
minor fix to place_in_family
Fri Nov 16 14:19:38 2007 UTC (12 years, 3 months ago) by overbeek
Changes since 1.3: +50 -8 lines
major fixes to FigFams.pm, FigFam.pm, FFs.pm and FF.pm
Thu Nov 15 14:52:24 2007 UTC (12 years, 3 months ago) by overbeek
Changes since 1.2: +6 -0 lines
make tolerant to missing FIGfam data
Thu Nov 15 14:30:50 2007 UTC (12 years, 3 months ago) by overbeek
Changes since 1.1: +72 -14 lines
redone FIGfam stuff
Fri Oct 26 14:27:36 2007 UTC (12 years, 4 months ago) by overbeek
initial undebugged versions of FF.pm and FFs.pm
