[Bio] / FigKernelPackages / FC.pm Repository:
Log of /FigKernelPackages/FC.pm
Mon Oct 26 15:14:15 2009 UTC (10 years ago) by parrello
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.20: +13 -7 lines
Diff to previous 1.20
Fixed a bug in "co_occurrence_evidence".
Mon Oct 26 03:46:11 2009 UTC (10 years ago) by overbeek
Diff to previous 1.19
remove space that Bruce noticed
Thu Aug 27 19:42:21 2009 UTC (10 years, 2 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.18: +76 -84 lines
Diff to previous 1.18
Converted co-occurrence server to new technology.
Thu Aug 20 19:38:17 2009 UTC (10 years, 2 months ago) by overbeek
Diff to previous 1.17
peg1:peg2 for homologs causes graceful do nothing
Wed Aug 19 17:01:06 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.16: +73 -38 lines
Diff to previous 1.16
Added some documentation, changed warnings to trace messages for FCupdate.
Sun Aug 16 02:11:46 2009 UTC (10 years, 2 months ago) by overbeek
Changes since 1.15: +42 -42 lines
removed duplicate co_occurrence_evidence
Tue Aug 11 20:28:01 2009 UTC (10 years, 3 months ago) by overbeek
Changes since 1.14: +80 -0 lines
add co-occurs stuff
Fri May 8 21:24:38 2009 UTC (10 years, 6 months ago) by overbeek
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09
Changes since 1.13: +6 -4 lines
updates to co_occurrence rtns
Thu May 7 20:24:26 2009 UTC (10 years, 6 months ago) by overbeek
Changes since 1.12: +2 -2 lines
add parameter to co_occurs
Thu May 7 16:35:27 2009 UTC (10 years, 6 months ago) by overbeek
Changes since 1.11: +30 -0 lines
add co-occurrence of FIGfams
Wed May 6 22:31:12 2009 UTC (10 years, 6 months ago) by overbeek
Changes since 1.10: +6 -5 lines
return score with clusters
Wed May 6 22:24:50 2009 UTC (10 years, 6 months ago) by overbeek
change blast cutoff
Wed May 6 20:42:35 2009 UTC (10 years, 6 months ago) by overbeek
Changes since 1.8: +35 -0 lines
add clustering stuff
Sat Mar 14 10:54:43 2009 UTC (10 years, 8 months ago) by overbeek
CVS Tags: rast_rel_2009_03_26
Changes since 1.7: +130 -36 lines
basically debugged
Wed Mar 11 02:02:49 2009 UTC (10 years, 8 months ago) by overbeek
Changes since 1.6: +42 -15 lines
version going to Bruce
Tue Mar 10 23:57:14 2009 UTC (10 years, 8 months ago) by overbeek
minor fixes
Tue Mar 10 03:35:23 2009 UTC (10 years, 8 months ago) by parrello
Changes since 1.4: +31 -9 lines
Completed update methods.
Mon Mar 9 14:42:27 2009 UTC (10 years, 8 months ago) by overbeek
Changes since 1.3: +12 -0 lines
define some primitives that Bruce will fill in
Sun Mar 8 18:38:39 2009 UTC (10 years, 8 months ago) by overbeek
Changes since 1.2: +249 -2 lines
not completely debugged co-occurrence code
Sat Mar 7 14:22:18 2009 UTC (10 years, 8 months ago) by overbeek
updates relating to functional coupling and evidence
Sat Mar 7 00:10:41 2009 UTC (10 years, 8 months ago) by overbeek
code to compute estimates of functional coupling
