[Bio] / FigKernelPackages / ExpressionDir.pm Repository:
Log of /FigKernelPackages/ExpressionDir.pm
Mon Mar 21 18:08:40 2011 UTC (9 years, 2 months ago) by olson
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.9: +62 -6 lines
Support for duplicate match removal.
Support for using Subsystems/{bindings,subsystems} in the genome directory. No support
yet for filling that data in on creation.
Fri Feb 4 22:55:11 2011 UTC (9 years, 3 months ago) by overbeek
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2
Changes since 1.8: +75 -1 lines
added Pearson coeff stuff
Mon Jan 24 19:42:26 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.7: +50 -30 lines
Support for peg.id.corr genomes like 272843.1
Mon Jan 24 18:16:35 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.6: +153 -2 lines
Add support for jobs with chip_id => locus tag mappings
Thu Jan 20 22:05:57 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.5: +117 -5 lines
sif processing, thermus parsing.
Fri Jan 14 20:06:51 2011 UTC (9 years, 4 months ago) by olson
CVS Tags: rast_rel_2011_0119
Changes since 1.4: +70 -4 lines
update
Fri Jan 7 22:20:55 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.3: +293 -43 lines
Update to expression pipeline code
Fri Jan 7 17:27:15 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.2: +69 -1 lines
add more stuff
Thu Jan 6 22:57:32 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.1: +86 -2 lines
more expression hacking
Wed Jan 5 21:38:44 2011 UTC (9 years, 4 months ago) by olson
new expression stuff
