[Bio] / FigKernelPackages / ExpressionDir.pm Repository:
Log of /FigKernelPackages/ExpressionDir.pm
Tue Nov 1 20:03:18 2011 UTC (8 years, 6 months ago) by olson
CVS Tags: HEAD, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.11: +9 -0 lines
Diff to previous 1.11 , to selected 1.9
add compute_pearson_corr
Tue Apr 19 19:55:47 2011 UTC (9 years, 1 month ago) by overbeek
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_rel40, rast_rel_2011_0928
Changes since 1.10: +18 -1 lines
Diff to previous 1.10 , to selected 1.9
fixes for subsystem estimates
Mon Mar 21 18:08:40 2011 UTC (9 years, 2 months ago) by olson
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.9: +62 -6 lines
Support for duplicate match removal.
Support for using Subsystems/{bindings,subsystems} in the genome directory. No support
yet for filling that data in on creation.
Revision 1.9 - (view) (download) (as text) (annotate) - [selected]
Fri Feb 4 22:55:11 2011 UTC (9 years, 3 months ago) by overbeek
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2
Changes since 1.8: +75 -1 lines
added Pearson coeff stuff
Mon Jan 24 19:42:26 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.7: +50 -30 lines
Diff to previous 1.7 , to selected 1.9
Support for peg.id.corr genomes like 272843.1
Mon Jan 24 18:16:35 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.6: +153 -2 lines
Diff to previous 1.6 , to selected 1.9
Add support for jobs with chip_id => locus tag mappings
Thu Jan 20 22:05:57 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.5: +117 -5 lines
Diff to previous 1.5 , to selected 1.9
sif processing, thermus parsing.
Fri Jan 14 20:06:51 2011 UTC (9 years, 4 months ago) by olson
CVS Tags: rast_rel_2011_0119
Changes since 1.4: +70 -4 lines
Diff to previous 1.4 , to selected 1.9
update
Fri Jan 7 22:20:55 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.3: +293 -43 lines
Diff to previous 1.3 , to selected 1.9
Update to expression pipeline code
Fri Jan 7 17:27:15 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.2: +69 -1 lines
Diff to previous 1.2 , to selected 1.9
add more stuff
Thu Jan 6 22:57:32 2011 UTC (9 years, 4 months ago) by olson
Changes since 1.1: +86 -2 lines
Diff to previous 1.1 , to selected 1.9
more expression hacking
Wed Jan 5 21:38:44 2011 UTC (9 years, 4 months ago) by olson
Diff to selected 1.9
new expression stuff
