[Bio] / FigKernelPackages / DocUtils.pm Repository:
Log of /FigKernelPackages/DocUtils.pm
Tue Aug 4 18:19:59 2009 UTC (10 years, 6 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.17: +129 -0 lines
Diff to previous 1.17
Added documentation functions to the Sapling server.
Tue Sep 9 23:47:53 2008 UTC (11 years, 5 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_release_2008_09_29
Changes since 1.16: +14 -5 lines
Diff to previous 1.16
Fixed a bug in the config file modification method and added tracing.
Tue Apr 29 04:49:13 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.15: +28 -178 lines
Revamped to allow more general processing of log files.
Thu Feb 7 00:07:23 2008 UTC (12 years ago) by parrello
CVS Tags: rast_rel_2008_04_23
Added support for RealCoreGenomes.
Wed Feb 6 23:51:18 2008 UTC (12 years ago) by parrello
Changes since 1.13: +11 -1 lines
Added support for list references and hash references in the modify-config-file method.
Tue Feb 5 01:08:09 2008 UTC (12 years ago) by parrello
Changes since 1.12: +181 -232 lines
Removed obsolete POD stuff.
Thu Dec 6 13:42:07 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.11: +14 -92 lines
Removed obsolete PerlDoc method.
Mon Oct 2 02:54:23 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.10: +20 -17 lines
Fixed CheckFile to handle nonexistent directories better.
Wed Jul 26 14:47:46 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.9: +12 -3 lines
Added some stuff to allow java compiling.
Sun Jul 23 17:47:27 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.8: +14 -4 lines
Added capability to the ModifyConfigFile that inserts assignments near the top of the file. The variables used in these assignments can be referred to in subsequent assignments.
Sun Jun 18 06:48:07 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.7: +12 -3 lines
Changed POD utility to return the computed documentation file name.
Mon Jun 5 05:46:18 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.6: +24 -5 lines
Fixed so that an error occurs if the trailing "1;" is not found in a config module when performing a config module update.
Wed May 10 03:02:15 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.5: +119 -0 lines
Added a utility method for updating config.pm files.
Mon Mar 13 19:16:52 2006 UTC (13 years, 11 months ago) by parrello
Changes since 1.4: +224 -219 lines
Fixed to work better with the directory structure used for the frame interface.
Wed Dec 7 19:38:22 2005 UTC (14 years, 2 months ago) by golsen
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one.  Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Added license words.
Wed May 4 02:57:23 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.1: +16 -3 lines
Tue Apr 5 05:25:57 2005 UTC (14 years, 10 months ago) by parrello
