Thu Mar 2 22:19:45 2006 UTC (13 years, 11 months ago) by overbeek
Diff to previous 1.26 , to selected 1.12
Fri Jan 6 20:20:40 2006 UTC (14 years ago) by olson
Diff to previous 1.25 , to selected 1.12
Tue Jan 3 20:52:38 2006 UTC (14 years ago) by olson
Diff to previous 1.24 , to selected 1.12
SQLite support.
Diff to previous 1.23 , to selected 1.12
Added license words.
Tue Nov 22 17:24:17 2005 UTC (14 years, 2 months ago) by olson
Diff to previous 1.22 , to selected 1.12
Tue Aug 16 19:41:12 2005 UTC (14 years, 5 months ago) by overbeek
Diff to previous 1.21 , to selected 1.12
NMPDR updates
Wed Jul 27 17:56:13 2005 UTC (14 years, 6 months ago) by olson
Diff to previous 1.20 , to selected 1.12
Fri Jun 24 21:40:16 2005 UTC (14 years, 7 months ago) by parrello
Diff to previous 1.19 , to selected 1.12
Wed Jun 15 16:24:37 2005 UTC (14 years, 7 months ago) by olson
CVS Tags: Root-bobdev_news
Diff to previous 1.18 , to selected 1.12
Thu Jun 9 18:34:16 2005 UTC (14 years, 7 months ago) by parrello
Diff to previous 1.17 , to selected 1.12
Wed Jun 1 01:18:50 2005 UTC (14 years, 8 months ago) by overbeek
Diff to previous 1.16 , to selected 1.12
Tue May 17 16:04:08 2005 UTC (14 years, 8 months ago) by olson
Diff to previous 1.15 , to selected 1.12
Wed May 11 18:43:19 2005 UTC (14 years, 8 months ago) by olson
Diff to previous 1.14 , to selected 1.12
Thu Apr 21 17:56:29 2005 UTC (14 years, 9 months ago) by disz
Diff to previous 1.13 , to selected 1.12
added genome package analyzer
Tue Apr 12 22:58:32 2005 UTC (14 years, 9 months ago) by redwards
debugging load_attributes
Revision 1.12 - (view) (download) (as text) (annotate) - [selected]
Fri Apr 8 08:32:10 2005 UTC (14 years, 9 months ago) by olson
Thu Apr 7 17:31:59 2005 UTC (14 years, 9 months ago) by olson
Diff to previous 1.10 , to selected 1.12
add get_inserted_id
Sun Feb 27 14:05:58 2005 UTC (14 years, 11 months ago) by olson
Diff to previous 1.9 , to selected 1.12
Sat Feb 26 23:32:45 2005 UTC (14 years, 11 months ago) by olson
Diff to previous 1.8 , to selected 1.12
Tue Jan 25 04:44:22 2005 UTC (15 years ago) by redwards
Diff to previous 1.7 , to selected 1.12
Tue Jan 11 18:59:39 2005 UTC (15 years ago) by olson
Diff to previous 1.6 , to selected 1.12
argument.
Sun Nov 7 23:07:34 2004 UTC (15 years, 2 months ago) by olson
Diff to previous 1.5 , to selected 1.12
DB params needed for gendb.
Mon Nov 1 20:20:09 2004 UTC (15 years, 2 months ago) by olson
Diff to previous 1.4 , to selected 1.12
Wed Oct 27 15:04:10 2004 UTC (15 years, 3 months ago) by olson
Diff to previous 1.3 , to selected 1.12
fixes for mysql
Thu Jul 1 21:16:34 2004 UTC (15 years, 7 months ago) by olson
Diff to previous 1.2 , to selected 1.12
add get_tables, table_exists
Tue Jan 6 11:52:31 2004 UTC (16 years ago) by overbeek
Diff to previous 1.1 , to selected 1.12
translate auto_assignments
Mon Dec 1 16:54:26 2003 UTC (16 years, 2 months ago) by efrank
Branch point for: initial
Diff to selected 1.12
