[Bio] / FigKernelPackages / Correspondence.pm Repository:
Log of /FigKernelPackages/Correspondence.pm
Sat Nov 20 19:06:00 2010 UTC (9 years, 2 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
correct the identity check
Wed Nov 17 21:13:05 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.2: +19 -10 lines
add support for 19-column tables and null $sap in entry_meets_criteria()
Wed Nov 17 20:46:23 2010 UTC (9 years, 3 months ago) by disz
Changed minPsc to maxPsc
Tue Nov 9 22:15:10 2010 UTC (9 years, 3 months ago) by olson
Correspondence table utilities.
