[Bio] / FigKernelPackages / ContigMD5.pm Repository:
Log of /FigKernelPackages/ContigMD5.pm
Tue May 1 16:50:24 2007 UTC (13 years ago) by olson
clone the digest so that checksum() may be called multiple times
Tue May 1 16:30:32 2007 UTC (13 years ago) by olson
doh
Wed Mar 7 20:39:20 2007 UTC (13 years, 2 months ago) by olson
Diff to selected 1.3
little module to help compute contig checksum
