[Bio] / FigKernelPackages / ContigMD5.pm Repository:
Log of /FigKernelPackages/ContigMD5.pm
Tue May 1 16:50:24 2007 UTC (12 years, 7 months ago) by olson
clone the digest so that checksum() may be called multiple times
Tue May 1 16:30:32 2007 UTC (12 years, 7 months ago) by olson
doh
Wed Mar 7 20:39:20 2007 UTC (12 years, 9 months ago) by olson
little module to help compute contig checksum
