[Bio] / FigKernelPackages / CompareMR.pm Repository:
Log of /FigKernelPackages/CompareMR.pm
Fri Sep 12 01:47:15 2008 UTC (11 years, 9 months ago) by overbeek
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
fixes to FIGV.pm, CompareMR.pm and FIG.pm to support comparison of metabolic reconstructions
Fri Jun 27 21:57:12 2008 UTC (12 years ago) by dsouza
Changes since 1.3: +4 -1 lines
Changed sort to make more efficient -- was taking very long.
Wed May 9 15:54:29 2007 UTC (13 years, 2 months ago) by paarmann
Changes since 1.2: +21 -21 lines
fixed compatibility issue with seed viewer
Mon Mar 12 01:13:23 2007 UTC (13 years, 4 months ago) by overbeek
Changes since 1.1: +12 -3 lines
basic ability to compare metabolic reconstructions
Sun Mar 11 20:37:54 2007 UTC (13 years, 4 months ago) by overbeek
Diff to selected 1.3
basic stuff for comparing metabolic reconstructions
