[Bio] / FigKernelPackages / Cluster.pm Repository:
Log of /FigKernelPackages/Cluster.pm
Changes since 1.10: +17 -0 lines
Added license words.
Sun Feb 27 14:06:19 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.9: +8 -3 lines
More cluster fixes.
Sun Feb 27 04:24:21 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.8: +0 -67 lines
Split the Cluster::Worker package out to its own file so it can be used
on hosts that don't have a full SEED installed.
Sun Feb 27 04:18:51 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.7: +141 -11 lines
More fixes to cluster code.
Sat Feb 26 23:33:06 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.6: +288 -81 lines
First working cut at the cluster stuff.
Sat Feb 26 02:42:41 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.5: +1073 -102 lines
more updates.
Wed Feb 16 21:55:23 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.4: +3 -1 lines
Fix insertion stuff for postgrs.
Wed Feb 16 21:51:40 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.3: +6 -6 lines
bugfix
Wed Feb 16 21:46:27 2005 UTC (14 years, 11 months ago) by olson
fix typo.
Wed Feb 16 21:41:47 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.1: +270 -0 lines
more stuff.
Thu Feb 10 16:55:56 2005 UTC (14 years, 11 months ago) by olson
Add db-based cluster job management thingie.
