[Bio] / FigKernelPackages / CloseStrains.pm Repository:
Log of /FigKernelPackages/CloseStrains.pm
Mon Mar 25 21:53:18 2019 UTC (12 months ago) by gdpusch
CVS Tags: HEAD
Changes since 1.31: +1 -1 lines
Diff to previous 1.31
Corrected typo in the description of columns 6 and 7 of the "Signature Output" table from "fifth column" to "sixth column".
Wed Nov 15 19:25:06 2017 UTC (2 years, 4 months ago) by olson
Changes since 1.30: +20 -0 lines
Diff to previous 1.30
Add support for pulling genomes from PATRIC
Tue Sep 29 20:43:29 2015 UTC (4 years, 5 months ago) by overbeek
Changes since 1.29: +2 -2 lines
Diff to previous 1.29
fix temp for sorts
Thu Jul 30 19:44:45 2015 UTC (4 years, 7 months ago) by overbeek
Changes since 1.28: +3 -1 lines
Diff to previous 1.28
minor changes in help
Wed Jul 29 21:10:01 2015 UTC (4 years, 8 months ago) by overbeek
Changes since 1.27: +6 -3 lines
Diff to previous 1.27
added adjacency
Tue Jul 28 01:11:42 2015 UTC (4 years, 8 months ago) by overbeek
Diff to previous 1.26
wc1/wc screwup
Tue Jul 28 01:08:16 2015 UTC (4 years, 8 months ago) by overbeek
Changes since 1.25: +4 -5 lines
Diff to previous 1.25
minor fixes
Sat Jul 25 21:23:47 2015 UTC (4 years, 8 months ago) by overbeek
Changes since 1.24: +4 -4 lines
Diff to previous 1.24
minor change in help text
Thu Jul 23 14:09:39 2015 UTC (4 years, 8 months ago) by overbeek
Changes since 1.23: +5 -4 lines
Diff to previous 1.23
links to pegs
Wed Jul 22 22:09:02 2015 UTC (4 years, 8 months ago) by overbeek
Changes since 1.22: +11 -12 lines
Diff to previous 1.22
fixes for reactions
Thu Jun 25 18:33:47 2015 UTC (4 years, 9 months ago) by overbeek
Changes since 1.21: +1 -1 lines
Diff to previous 1.21
cleanup tmp
Thu Jun 25 17:41:43 2015 UTC (4 years, 9 months ago) by overbeek
Changes since 1.20: +0 -1 lines
Diff to previous 1.20
get rid of debugging die
Sat Jun 20 13:12:45 2015 UTC (4 years, 9 months ago) by overbeek
Changes since 1.19: +82 -77 lines
Diff to previous 1.19
allow invoker to specify path to data directory
Thu Aug 7 21:03:25 2014 UTC (5 years, 7 months ago) by overbeek
CVS Tags: rast_rel_2014_0912
Changes since 1.18: +6 -3 lines
Diff to previous 1.18
counts in table headers
Thu Aug 7 18:06:02 2014 UTC (5 years, 7 months ago) by overbeek
Changes since 1.17: +27 -5 lines
Diff to previous 1.17
minor changes
Thu Jul 17 19:09:58 2014 UTC (5 years, 8 months ago) by olson
CVS Tags: rast_rel_2014_0729
Changes since 1.16: +31 -31 lines
Diff to previous 1.16
Re-merge RAST chagnes.
Thu Jul 17 15:45:05 2014 UTC (5 years, 8 months ago) by overbeek
bAD
Mon Jul 14 17:57:18 2014 UTC (5 years, 8 months ago) by overbeek
Changes since 1.14: +46 -10 lines
added gains/losses reactions
Sun Jul 13 19:51:02 2014 UTC (5 years, 8 months ago) by overbeek
Changes since 1.13: +526 -20 lines
update reaction stuff
Wed Jun 4 16:17:23 2014 UTC (5 years, 9 months ago) by olson
Changes since 1.12: +10 -0 lines
add diags to index creation
Tue Jun 3 17:17:15 2014 UTC (5 years, 9 months ago) by olson
Changes since 1.11: +4 -0 lines
set tmpdir
Tue Jun 3 17:08:51 2014 UTC (5 years, 9 months ago) by olson
Changes since 1.10: +76 -5 lines
index fix.
Mon Jun 2 21:04:02 2014 UTC (5 years, 9 months ago) by olson
Changes since 1.9: +5 -1 lines
When creating CS dir from web, don't look up references immediately.
Mon Jun 2 18:40:47 2014 UTC (5 years, 9 months ago) by olson
Changes since 1.8: +140 -44 lines
RAST/CS fixes
Sun May 25 14:41:07 2014 UTC (5 years, 10 months ago) by overbeek
Changes since 1.7: +44 -0 lines
added help
Fri May 23 18:19:42 2014 UTC (5 years, 10 months ago) by overbeek
Changes since 1.6: +45 -28 lines
changes in adjacency display
Thu May 22 15:44:28 2014 UTC (5 years, 10 months ago) by overbeek
Changes since 1.5: +4 -1 lines
mark RAST genomes
Thu May 15 14:26:32 2014 UTC (5 years, 10 months ago) by overbeek
Changes since 1.4: +131 -3 lines
added help
Wed May 14 19:13:42 2014 UTC (5 years, 10 months ago) by overbeek
Changes since 1.3: +15 -15 lines
wc1->wc
Wed May 14 18:59:29 2014 UTC (5 years, 10 months ago) by overbeek
Changes since 1.2: +125 -15 lines
add help
Mon May 12 18:04:02 2014 UTC (5 years, 10 months ago) by overbeek
Changes since 1.1: +280 -15 lines
restructured CS
Sun May 11 23:15:31 2014 UTC (5 years, 10 months ago) by overbeek
initial copy
