[Bio] / FigKernelPackages / ClientThing.pm Repository:
Log of /FigKernelPackages/ClientThing.pm
Fri Mar 18 15:57:39 2011 UTC (8 years, 11 months ago) by olson
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_release_3_0_3, myrast_33
Changes since 1.22: +8 -2 lines
Diff to previous 1.22
alternate fix :-) pull the initialization of the list to the constructor, ensure we send pairs of args
Fri Mar 18 15:37:08 2011 UTC (8 years, 11 months ago) by parrello
Changes since 1.21: +1 -1 lines
Diff to previous 1.21
Added eval protection for HTTP::Message::decodable call.
Thu Mar 17 21:32:30 2011 UTC (8 years, 11 months ago) by parrello
Diff to previous 1.20
More debugging fixes.
Thu Mar 17 19:01:42 2011 UTC (8 years, 11 months ago) by olson
CVS Tags: mgrast_release_3_0_2
Changes since 1.19: +7 -3 lines
Diff to previous 1.19
Flip default to PUBSEED.
Add support for compressed encodings.
Thu Feb 3 19:11:18 2011 UTC (9 years ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_release_3_0, mgrast_release_3_0_1
Changes since 1.18: +2 -0 lines
Diff to previous 1.18
add PUBSEED
Thu Dec 16 22:14:57 2010 UTC (9 years, 2 months ago) by parrello
CVS Tags: rast_rel_2011_0119
Diff to previous 1.17
Support for local SQLite servers.
Mon Nov 1 16:16:05 2010 UTC (9 years, 3 months ago) by olson
CVS Tags: rast_rel_2010_1206
Changes since 1.16: +3 -0 lines
Diff to previous 1.16
More analysis fixes; user-agent setting.
Sat Oct 30 13:52:58 2010 UTC (9 years, 3 months ago) by parrello
Changes since 1.15: +26 -1 lines
New Sapling update support.
Mon Aug 9 13:46:06 2010 UTC (9 years, 6 months ago) by parrello
Changes since 1.14: +45 -0 lines
Allow alternate forms of parameters to client-side modules.
Thu Jul 29 17:35:51 2010 UTC (9 years, 6 months ago) by parrello
Changes since 1.13: +92 -0 lines
Added support for using SAS_SERVER environment variable to configure the appropriate server.
Fri Dec 11 22:47:14 2009 UTC (10 years, 2 months ago) by parrello
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.12: +5 -1 lines
Fixed to produce a less ugly message when there is no response content from a server error.
Fri Dec 4 17:53:35 2009 UTC (10 years, 2 months ago) by parrello
Insured that the "methods" method is always legal.
Thu Dec 3 15:32:37 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.10: +20 -23 lines
Changed tabs to spaces.
Wed Dec 2 20:28:49 2009 UTC (10 years, 2 months ago) by olson
Changes since 1.9: +2 -1 lines
add timestamps to fail/retry messages
Wed Nov 25 20:52:40 2009 UTC (10 years, 2 months ago) by parrello
Changed to always confess on error.
Wed Nov 25 19:19:49 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.7: +1 -2 lines
Wed Nov 25 19:16:42 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.6: +2 -1 lines
Wed Nov 25 18:57:07 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.5: +11 -2 lines
Added more error information if $ENV{SAS_DEBUG} is set.
Wed Nov 25 01:03:47 2009 UTC (10 years, 2 months ago) by olson
add retries to COserver
remove 500 from list of error codes to retry, since that is a real failure.
Tue Nov 24 22:23:28 2009 UTC (10 years, 2 months ago) by olson
Changes since 1.3: +39 -8 lines
add retries
Fri Nov 6 21:38:42 2009 UTC (10 years, 3 months ago) by olson
Reset LWP::UserAgent timeout.
Tue Nov 3 21:20:07 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.1: +30 -20 lines
Error handling restructure.
Thu Oct 29 18:26:59 2009 UTC (10 years, 3 months ago) by parrello
Final server updates.
