[Bio] / FigKernelPackages / Clearinghouse.pm Repository:
Log of /FigKernelPackages/Clearinghouse.pm
Fri Aug 15 20:01:18 2008 UTC (11 years, 4 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_release_2008_09_29
fix clearinghouse urls.
CVS Tags: caBIG-05Apr06-00, caBIG-13Feb06-00, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07
Added license words.
Mon Aug 1 22:22:13 2005 UTC (14 years, 4 months ago) by parrello
Changed attributes to capital-case in order to prevent the avalanche of compile-time warnings.
Tue Jun 8 15:02:14 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.1: +5 -1 lines
Add capability for :scalar :list :remote annotations to FIG interface. This works with
modules that are declared as subclasses of FIGAttributes.
Wed Apr 28 21:59:32 2004 UTC (15 years, 7 months ago) by olson
Clearinghouse publishing stuff
