[Bio] / FigKernelPackages / ChromosomalClusters.pm Repository:
Log of /FigKernelPackages/ChromosomalClusters.pm
Mon Sep 17 19:52:10 2007 UTC (12 years, 4 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_release_2008_09_29
Changes since 1.9: +42 -5 lines
fix typoe
Tue Sep 5 17:00:00 2006 UTC (13 years, 4 months ago) by paczian
updated evidece_codes to comply to the new way evidence codes are stored in the attributes
Fri Jul 14 22:24:44 2006 UTC (13 years, 6 months ago) by parrello
Fixed obsolete form of boundaries_of.
Thu Jun 29 00:18:40 2006 UTC (13 years, 7 months ago) by overbeek
RAE: fixing broken line
Tue Mar 21 15:53:30 2006 UTC (13 years, 10 months ago) by overbeek
fixes to split_and_trim
Fri Mar 3 23:09:29 2006 UTC (13 years, 10 months ago) by golsen
Changes since 1.4: +3 -2 lines
Minor change in information displayed on contig abbreviation mouse-over.
Fri Mar 3 22:36:37 2006 UTC (13 years, 10 months ago) by golsen
Changes since 1.3: +3 -1 lines
Add genome name pop-up on mouse-over of title abbreviations to chromosomal
cluster and pinned region views.  Added infrastructure for links and
context menus, too.  Changes to GenoGraphics also adjust left margin
of the diagrams to match the actual title lengths.
Wed Jan 25 20:44:42 2006 UTC (14 years ago) by olson
Doh, leetle typo.
Wed Jan 25 18:56:57 2006 UTC (14 years ago) by olson
small tweak to batch pin computation.
Wed Jan 25 17:19:31 2006 UTC (14 years ago) by olson
factor out pin-generation code so we can do it in bulk.
