[Bio] / FigKernelPackages / COserver.pm Repository:
Log of /FigKernelPackages/COserver.pm
Thu Dec 17 20:48:21 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.12: +0 -4 lines
Removed from the SAS distribution.
Tue Dec 1 23:43:22 2009 UTC (10 years, 2 months ago) by parrello
Changed to use the default URL if an empty string is specified, for compatibility with some of the scripts.
Mon Nov 30 11:45:22 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.10: +5 -249 lines
Converted to use ClientThing.
Wed Nov 25 21:58:39 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.9: +1 -0 lines
Fixed missing use.
Wed Nov 25 21:23:18 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.8: +7 -4 lines
updated error handling
Wed Nov 25 01:03:47 2009 UTC (10 years, 2 months ago) by olson
Changes since 1.7: +40 -8 lines
add retries to COserver
remove 500 from list of error codes to retry, since that is a real failure.
Fri Nov 6 22:54:13 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.6: +1 -0 lines
reset client timeouts here too
Thu Nov 5 20:59:01 2009 UTC (10 years, 3 months ago) by parrello
Restored missing URLs.
Tue Nov 3 21:20:07 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.4: +141 -48 lines
Error handling restructure.
Thu Oct 1 23:42:48 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.3: +168 -59 lines
Converted to new technology.
Fri Jun 19 17:30:02 2009 UTC (10 years, 8 months ago) by olson
Changes since 1.2: +4 -0 lines
server fixes
Mon May 11 20:36:35 2009 UTC (10 years, 9 months ago) by olson
CVS Tags: rast_rel_2009_05_18
fixes to use the canonical server url
Mon May 11 16:42:42 2009 UTC (10 years, 9 months ago) by disz
CLient side package to access CO server
