[Bio] / FigKernelPackages / CO.pm Repository:
Log of /FigKernelPackages/CO.pm
Fri Dec 4 20:12:14 2009 UTC (10 years, 6 months ago) by disz
Changes since 1.5: +7 -1 lines
changed doc to say XXserver->new() insetad of XX->new
Tue Nov 3 21:20:07 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.4: +23 -0 lines
Error handling restructure.
Mon Oct 26 15:13:49 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.3: +67 -2 lines
Added new "co_occurrence_evidence" method.
Tue Oct 20 20:37:30 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.2: +19 -10 lines
Added a hash-format output option.
Wed Sep 9 15:23:02 2009 UTC (10 years, 8 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.1: +6 -6 lines
Fixed some documentation errors.
Thu Aug 27 19:42:21 2009 UTC (10 years, 9 months ago) by parrello
Diff to selected 1.3
Converted co-occurrence server to new technology.
