[Bio] / FigKernelPackages / ButtonArray.pm Repository:
Log of /FigKernelPackages/ButtonArray.pm
Sat Feb 2 20:54:37 2008 UTC (12 years ago) by golsen
Two subroutines to support a user ordering of items.  Created for the
compare genomes function, but written to work with any set of items
that might be ordered.
