[Bio] / FigKernelPackages / Blast.pm Repository:
Log of /FigKernelPackages/Blast.pm
Tue Feb 12 14:25:50 2008 UTC (11 years, 9 months ago) by overbeek
Changes since 1.4: +3 -0 lines
close TMP files in Blast.pm
Thu Feb 7 21:35:39 2008 UTC (11 years, 9 months ago) by overbeek
Changes since 1.3: +0 -2 lines
implemented new version of dsims based on partitions
Mon Dec 5 19:06:30 2005 UTC (13 years, 11 months ago) by olson
Added license words.
Wed Aug 11 12:15:11 2004 UTC (15 years, 3 months ago) by olson
Force blastall and formatdb to be run using a full path to $FIG_Config::ext_bin.
Mon Dec 1 16:54:26 2003 UTC (15 years, 11 months ago) by efrank
Branch point for: initial
