[Bio] / FigKernelPackages / BerkTable.pm Repository:
Log of /FigKernelPackages/BerkTable.pm
Wed Sep 15 21:46:25 2010 UTC (9 years, 5 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
fix arg
Wed Jun 16 20:21:50 2010 UTC (9 years, 8 months ago) by olson
CVS Tags: rast_rel_2010_0827
Major update to figfams code. Remove old FigFam/FigFams modules that were tied to the
original decision procedure; update FF/FFs to use the Kmer-based stuff. Add new berkeley
db table processing routines to SeedUtils.
