[Bio] / FigKernelPackages / Assignments.pm Repository:
Log of /FigKernelPackages/Assignments.pm
Wed Sep 10 20:09:55 2008 UTC (11 years, 5 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.16: +13 -66 lines
Diff to previous 1.16 , to selected 1.10
remove impact of our annotations on making assignments using auto_assign
Tue Jun 12 21:35:35 2007 UTC (12 years, 8 months ago) by overbeek
Changes since 1.15: +0 -1 lines
Diff to previous 1.15 , to selected 1.10
fix Assignments.pm
Tue Jun 12 21:32:30 2007 UTC (12 years, 8 months ago) by overbeek
Diff to previous 1.14 , to selected 1.10
fix error in index.cgi
Mon May 7 14:42:49 2007 UTC (12 years, 9 months ago) by overbeek
Diff to previous 1.13 , to selected 1.10
leave count of subs as not just those made by curator
Mon May 7 14:22:20 2007 UTC (12 years, 9 months ago) by overbeek
Changes since 1.12: +29 -2 lines
Diff to previous 1.12 , to selected 1.10
alter auto_assign to increment for subsystems only when curator made the aSSIGNMENT
Wed May 3 15:55:21 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.11: +68 -69 lines
Diff to previous 1.11 , to selected 1.10
fixes to Assignments.pm
Wed May 3 13:18:22 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.10: +65 -23 lines
 update genome parameters in default assignments
Revision 1.10 - (view) (download) (as text) (annotate) - [selected]
Thu Apr 13 10:45:03 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.9: +9 -301 lines
dynamically determine trusted subsystems
Sun Feb 19 04:15:44 2006 UTC (14 years ago) by overbeek
Changes since 1.8: +5 -1 lines
Diff to previous 1.8 , to selected 1.10
minor fixes to auto_assign
Wed Feb 15 22:12:26 2006 UTC (14 years ago) by overbeek
Changes since 1.7: +67 -151 lines
Diff to previous 1.7 , to selected 1.10
minor fixes to assignment for close strains
Thu Jan 26 03:36:47 2006 UTC (14 years ago) by overbeek
Changes since 1.6: +2 -2 lines
Diff to previous 1.6 , to selected 1.10
add check_anno.cgi
Thu Dec 22 00:52:43 2005 UTC (14 years, 2 months ago) by overbeek
Diff to previous 1.5 , to selected 1.10
minor fix to auto_assign
Wed Dec 21 22:58:01 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.4: +4 -1 lines
Diff to previous 1.4 , to selected 1.10
clean up some of the output for auto_assign
Diff to previous 1.3 , to selected 1.10
Added license words.
Wed Aug 17 12:24:43 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.2: +398 -180 lines
Diff to previous 1.2 , to selected 1.10
fixes to automated assignments
Sun Aug 14 01:47:51 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.1: +1 -2 lines
Diff to previous 1.1 , to selected 1.10
fixes to auto_assign via Assignments.pm
Fri Jun 3 14:32:27 2005 UTC (14 years, 8 months ago) by overbeek
Diff to selected 1.10
clean up of auto assignments routines
