[Bio] / FigKernelPackages / Assignments.pm Repository:
Log of /FigKernelPackages/Assignments.pm
Tue Jun 12 21:35:35 2007 UTC (12 years, 7 months ago) by overbeek
Changes since 1.15: +0 -1 lines
fix Assignments.pm
Tue Jun 12 21:32:30 2007 UTC (12 years, 7 months ago) by overbeek
fix error in index.cgi
Mon May 7 14:42:49 2007 UTC (12 years, 8 months ago) by overbeek
leave count of subs as not just those made by curator
Mon May 7 14:22:20 2007 UTC (12 years, 8 months ago) by overbeek
Changes since 1.12: +29 -2 lines
alter auto_assign to increment for subsystems only when curator made the aSSIGNMENT
Wed May 3 15:55:21 2006 UTC (13 years, 8 months ago) by overbeek
Changes since 1.11: +68 -69 lines
fixes to Assignments.pm
Wed May 3 13:18:22 2006 UTC (13 years, 8 months ago) by overbeek
Changes since 1.10: +65 -23 lines
 update genome parameters in default assignments
Thu Apr 13 10:45:03 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.9: +9 -301 lines
dynamically determine trusted subsystems
Sun Feb 19 04:15:44 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.8: +5 -1 lines
minor fixes to auto_assign
Wed Feb 15 22:12:26 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.7: +67 -151 lines
minor fixes to assignment for close strains
Thu Jan 26 03:36:47 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.6: +2 -2 lines
add check_anno.cgi
Thu Dec 22 00:52:43 2005 UTC (14 years, 1 month ago) by overbeek
minor fix to auto_assign
Wed Dec 21 22:58:01 2005 UTC (14 years, 1 month ago) by overbeek
Changes since 1.4: +4 -1 lines
clean up some of the output for auto_assign
Added license words.
Wed Aug 17 12:24:43 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.2: +398 -180 lines
fixes to automated assignments
Sun Aug 14 01:47:51 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.1: +1 -2 lines
fixes to auto_assign via Assignments.pm
Fri Jun 3 14:32:27 2005 UTC (14 years, 7 months ago) by overbeek
clean up of auto assignments routines
