[Bio] / FigKernelPackages / Assignments.pm Repository:
View of /FigKernelPackages/Assignments.pm
Revision 1.17 - (download) (as text) (annotate)
Wed Sep 10 20:09:55 2008 UTC (11 years, 5 months ago) by overbeek
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, myrast_rel40, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, HEAD
Changes since 1.16: +13 -66 lines
remove impact of our annotations on making assignments using auto_assign
# Public License.
package Assignments;
use Carp;
use Data::Dumper;
use FIG;
use SameFunc;
sub default_parms {
    my $x = <<END
external	sp	4
external	img	4
external	uni	1.3
external	kegg	1
external	gi	1
END
# TO PUT FIG ANNOTATIONS BACK IN ADD THE FOLLOWING LINE
#subsystems	trusted	20
# You may also improve things by adding lines like:
#genome	83333.1	15	Escherichia coli K12
    my @parms = split(/\n/,$x);
    my $fig = new FIG;
    my @trusted_subsystems = map { my $sub = $_; my $curr = $fig->subsystem_curator($sub);
				   "$sub\t$curr\n"
                             grep { $fig->usable_subsystem($_) }
                             $fig->all_subsystems;
    push(@parms,@trusted_subsystems,"//\n");
    return @parms;
sub choose_best_assignment {
    my($fig,$parms,$pegs,$external_ids,$ignore) = @_;
    my($peg,$id);
    my $functions = {};
    foreach $peg (@$pegs)
	&load_peg_function($fig,$parms,$peg,$functions);
    my @tmp = keys(%$functions);
    print STDERR &Dumper(['peg check',\@tmp,$functions]) if ($ENV{'DEBUG'} || $ENV{'VERBOSE'});
    if ((@tmp == 1) && (@$pegs >= 5)) { return $tmp[0] }
    foreach $id (@$external_ids)
	&load_ext_function($fig,$parms,$id,$functions);
    return &cleanup(&pick_function($fig,$parms,$functions));
sub cleanup {
    my($func) = @_;
    if (! $func)                                           { return "hypothetical protein" }
    if ($func =~ /^hypothetical (\S+ )?protein .*$/i)      { return "hypothetical protein" }
    if ($func =~ /^[a-zA-Z]{1,2}\d{2,5}( protein)?$/i)     { return "hypothetical protein" }
    if ($func =~ /^similar to ORF\d+$/)                    { return "hypothetical protein" }
    if ($func =~ /^(Alr|As|All|Tlr|Tll|Glr|Blr|Slr|SEW|pANL)\d+( protein)?$/i) { return "hypothetical protein" }
    if ($func =~ /^\d{5}/)                                 { return "hypothetical protein" }
    if ($func =~ /unknown protein/)                        { return "hypothetical protein" }
    return $func;
sub pick_function {
    my($fig,$parms,$functions) = @_;
    my($set,$score,$best_source,$poss_function);
    my(@scored);
    my @partitions = &SameFunc::group_funcs(keys(%$functions));
    if ($ENV{'VERBOSE'}) {  print STDERR "partition: ",&Dumper(\@partitions,$functions); }
    foreach $set (@partitions)
	$score = &score_set($set,$functions);
	if ($ENV{'DEBUG'}) { print STDERR &Dumper([$score,$set]); }
        if ($ENV{'DEBUG'}) { print STDERR "picking from set ",&Dumper($set); }
	($poss_function,$best_source) = &pick_specific($fig,$parms,$set,$functions);
 	if ($ENV{'DEBUG'}) { print STDERR "picked $poss_function from $best_source\n"; }
	push(@scored,[$score,$poss_function,$best_source]);
    @scored = sort { $b->[0] <=> $a->[0] } @scored;
    if ((@scored > 1) && $ENV{'VERBOSE'})
	foreach $_ (@scored)
	    print STDERR join("\t",@$_),"\n";
	print STDERR "//\n";
    return (@scored > 0) ? $scored[0]->[1] : "";
sub score_set {
    my($set,$functions) = @_;
    my($func,$x);
    my $score = 0;
    foreach $func (@$set)
	if ($x = $functions->{$func})
	    foreach $_ (@$x)
		$score += $_->[0];
    return $score;
sub pick_specific {
    my($fig,$parms,$set,$functions) = @_;
    my($best_func,$best_score,$func,$x,$best_source);
    $best_func  = "";
    $best_score = 0;
    $best_source = "";
	    my $incr = @$x;
	    foreach $_ (@$x)
		my($sc,$peg,$in_sub) = @$_;
		$sc += $in_sub ? 10000 : 0;
		if (((100 * $sc) + $incr) > $best_score)
		    $best_score = (100 * $sc) + $incr;
		    $best_func  = $func;
		    $best_source = $peg;
    if ($ENV{'VERBOSE'}) { print STDERR &Dumper(["picked best source",$set,$functions,$best_func,$best_source]) }
    return ($best_func,$best_source);
sub load_ext_function {
    my($fig,$parms,$id,$functions) = @_;
    my $func = $fig->function_of($id);
    if ($func && # (! &FIG::hypo($func)) &&
	($id =~ /^([A-Za-z]{2,4})\|/) && ($_ = $parms->{'external'}->{$1}))
	push(@{$functions->{$func}},[$_,$id]);
sub load_peg_function {
    my($fig,$parms,$peg,$functions) = @_;
    my $func = $fig->function_of($peg);
    if ($func) # (! &FIG::hypo($func))
	my $value = 1;
	my $genome = &FIG::genome_of($peg);
	if ($_ = $parms->{'genome'}->{$genome})
	    $value += $_;
	my $subv = 0;
	my @subs = ();
	foreach my $sub ($fig->peg_to_subsystems($peg))
	    if (1) # (&solid_sub_assign($fig,$sub,$peg,$func))
		push(@subs,$sub);
	my $sub;
	my $in_sub = 0;
	foreach $sub (@subs)
	    if ($_ = $parms->{'subsystems'}->{$sub})
		if ($_ > $subv)
		    $subv = $_;
		$in_sub = 1;
	$value += $subv;
	push(@{$functions->{$func}},[$value,$peg,$in_sub]);
sub solid_sub_assign {
    my($fig,$sub,$peg,$func) = @_;
    my $curator = $fig->subsystem_curator($sub);
    $curator =~ s/^master://;
    return ($fig->usable_subsystem($sub) && &made_by_curator($fig,$peg,$func,$curator));
sub made_by_curator {
    my($fig,$peg,$func,$curator) = @_;
    my @ann = $fig->feature_annotations($peg,"rawtime");
    my $i;
    my $funcQ = quotemeta $func;
    for ($i=$#ann;
	 ($i >= 0) && (($ann[$i]->[2] !~ /$curator/) || ($ann[$i]->[3] !~ /Set \S+ function to\n$funcQ/s));
	 $i--) {}
    return ($i >= 0);
sub equivalent_ids {
    my($fig,$parms,$pegs) = @_;
    my($peg,@aliases,$alias,%external_ids,%pegs,$tuple);
	$pegs{$peg} = 1;
	@aliases = $fig->feature_aliases($peg);
	foreach $alias (@aliases)
	    if (($alias =~ /^([A-Za-z]{2,4})\|\S+$/) && $parms->{"external"}->{$1})
		$external_ids{$alias} = 1;
	foreach $tuple ($fig->mapped_prot_ids($peg))
	    if (($tuple->[0] =~ /^fig\|/) && $fig->is_real_feature($tuple->[0]))
		$pegs{$tuple->[0]} = 1;
	    elsif (($tuple->[0] =~ /^([A-Za-z]{2,4})\|\S+$/) && $parms->{"external"}->{$1})
		$external_ids{$tuple->[0]} = 1;
    return ([sort { &FIG::by_fig_id($a,$b) }  keys(%pegs)],[sort keys(%external_ids)]);
sub load_parms {
    my($parmsF) = @_;
    my @parmsS;
    my $wts = {};
    if ($parmsF)
	@parmsS = `cat $parmsF`;
    else
	@parmsS = &default_parms;
    while ($_ = shift @parmsS)
	chomp;
	my($type,$data,$val) = split(/\t/,$_);
	if ($type eq 'subsystems')
	    my $x;
	    while (($x = shift @parmsS) && ($x !~ /^\/\//))
		if ($x =~ /^(\S[^\t]+\S)/)
		    $wts->{$type}->{$1} = $val;
	else
	    $wts->{$type}->{$data} = $val;
    return $wts;
sub print_parms {
    my($parms) = @_;
    my($type,$data,$val,$wt_by_type);
    print STDERR "Parameters:\n";
    foreach $type (sort keys(%$parms))
	print STDERR "\n\t$type\n";
	$wt_by_type = $parms->{$type};
	foreach $data (sort keys(%$wt_by_type))
	    $val = $wt_by_type->{$data};
	    print STDERR "\t\t$data\t$val\n";
    print STDERR "\n";
1;
