[Bio] / FigKernelPackages / Annotation.pm Repository:
Log of /FigKernelPackages/Annotation.pm
Mon Feb 4 23:55:36 2008 UTC (12 years ago) by parrello
Changes since 1.3: +8 -0 lines
Added a TITLE statement for the Wiki.
Added license words.
Wed Nov 2 21:35:31 2005 UTC (14 years, 3 months ago) by parrello
CVS Tags: caBIG-00-00-00
Changes since 1.1: +9 -8 lines
Converted tabs to spaces.
Added parentheses to an assignment in the "new" method to prevent it from being evaluated in the wrong order.
Tue Sep 6 18:52:35 2005 UTC (14 years, 5 months ago) by olson
CVS Tags: caBIG-dataload-0
Make annotations_made_fast return new Annotation objects instead of arrays of data.
Add the Annotation object.
