[Bio] / FigKernelPackages / AliasAnalysis.pm Repository:
Log of /FigKernelPackages/AliasAnalysis.pm
Tue Jan 11 15:03:28 2011 UTC (9 years ago) by parrello
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.10: +0 -2 lines
Updates for single-genome loader.
Thu Feb 18 15:27:33 2010 UTC (9 years, 11 months ago) by parrello
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Fixed the LocusTag match pattern.
Tue Apr 21 16:00:41 2009 UTC (10 years, 9 months ago) by parrello
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118
Fixed the pattern for CMR IDs.
Tue Apr 7 14:08:58 2009 UTC (10 years, 9 months ago) by parrello
Fixed an error in the CMR pattern.
Thu Apr 2 04:27:09 2009 UTC (10 years, 9 months ago) by parrello
Changes since 1.6: +54 -0 lines
Added AliasCheck method and an alias blacklist.
Thu Apr 2 00:56:23 2009 UTC (10 years, 9 months ago) by parrello
Changes since 1.5: +59 -5 lines
Updated for better compatibility with the peg.synonyms database.
Sun Mar 15 23:53:44 2009 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.4: +66 -1 lines
Added support for harvesting IDs from the annotation clearinghouse.
Mon Mar 2 22:23:13 2009 UTC (10 years, 10 months ago) by parrello
Changes since 1.3: +178 -30 lines
Fixed a bug in the match patterns.
Thu Dec 6 13:32:01 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.2: +5 -5 lines
Mon Aug 20 23:02:14 2007 UTC (12 years, 5 months ago) by parrello
Changed a URL that used old-style GET syntax that is not compatible with XML.
Mon Jul 16 19:38:08 2007 UTC (12 years, 6 months ago) by parrello
Added as a first stab toward organizing information about alias types.
