[Bio] / FigKernelPackages / AliTrees.pm Repository:
Log of /FigKernelPackages/AliTrees.pm
Tue Sep 4 19:49:40 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.3: +3 -0 lines
fix AliTrees.pm to fail gracefully
Wed Aug 1 12:30:45 2007 UTC (12 years, 11 months ago) by olson
make lack of tree dir nonfatal; unbreaks theseed.uchicago
Fri Jul 13 22:37:49 2007 UTC (13 years ago) by overbeek
minor fixes to processing of alignments
Thu Jul 12 17:52:56 2007 UTC (13 years ago) by overbeek
Diff to selected 1.2
add AliTrees.pm and AliTree.pm - support for alignment library
