[Bio] / FigKernelPackages / AliTree.pm Repository:
View of /FigKernelPackages/AliTree.pm
Revision 1.5 - (download) (as text) (annotate)
Sat Sep 15 22:33:31 2007 UTC (12 years, 8 months ago) by overbeek
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
FIGfams are now broadened to include PEGs with mismatching functions
# -*- perl -*-
# Public License.
package AliTree;
use strict;
use FIG;
use SameFunc;
use gjoseqlib;
use gjoalignment;
use tree_utilities;
use PHOB;
use Tracer;
use AliTrees;
use Carp;
use Data::Dumper;
#### To turn on tracing, at the command line type
###  export TRACING=Ross
###  trace 3 AliTree
sub new {
    my($class,$id,$fig,$data) = @_;
    ($id =~ /^\d+\.\d+\.peg\.\d+/) || confess "invalid id: $id";
    if (! defined($fig)) { $fig = new FIG }
    if (! defined($data))
	if (-d "$FIG_Config::data/AlignmentsAndTrees")
	    $data = "$FIG_Config::data/AlignmentsAndTrees";
	else
	    confess "Where are the alignments and trees?";
    my $ali_tree      = {};
    $ali_tree->{id}   = $id;
    $ali_tree->{fig}  = $fig;
    $ali_tree->{data} = $data;
    my $dir = $ali_tree->{dir}  = "$data/Library/$id";
    if (! defined("$dir/full.ali"))   { return undef }
    my($ali,$core_ali);
    open(ALI,"<$dir/full.ali") || die "could not open $dir/full.ali";
    ($ali = &gjoseqlib::read_fasta(\*ALI)) || die "$dir/full.ali is not well-formatted fasta";
    close(ALI);
    if (open(ALI,"<$dir/core.ali") && ($core_ali = &gjoseqlib::read_fasta(\*ALI)))
	close(ALI);
    else
	$core_ali = undef;
    my @deleted = grep {$fig->is_deleted_fid($_->[0]) } @$ali;
    my %deleted;
    if (@deleted > 0)
	%deleted = map { $_->[0] => 1 } @deleted;
	$ali      = [grep { ! $deleted{$_->[0]} } @$ali];
	$core_ali = $core_ali ? [grep { ! $deleted{$_->[0]} } @$core_ali] : undef;
    if (@$ali < 2)         { return undef }
    my @coords = ();
    if (open(COORDS,"<$dir/coords"))
	@coords = map { chomp; [split(/\t/,$_)] } <COORDS>;
	close(COORDS);
    if (@coords > @$ali)
	@coords = grep { ! $deleted{$_->[0]} } @coords;
	open(COORDS,">$dir/coords") || die "could not update $dir/coords";
	foreach my $x (@coords)
	    print COORDS join("\t",@$x),"\n";
	close(COORDS);
    elsif (@coords < @$ali)
	for (my $tupleI = (@$ali - 1); ($tupleI >= 0); $tupleI--)
	    my $tuple = $ali->[$tupleI];
	    my($peg,undef,$seq) = @$tuple;
	    $seq =~ s/-//g;
	    $seq = lc $seq;
	    my $full_seq = lc $fig->get_translation($peg);
	    my($offset,$n);
	    if (($offset = index($full_seq,$seq)) >= 0)
		print COORDS join("\t",($peg,$offset+1,$offset + length($seq),length($full_seq))),"\n";
		push(@coords,[$peg,$offset+1,$offset + length($seq),length($full_seq)]);
	    elsif (($n = int(0.4 * length($full_seq))) &&
		   (($offset = index($full_seq,substr($seq,$n))) >= 0))
		$offset -= $n;
	    else
		push(@deleted,$peg);
		print STDERR "SERIOUS ERROR: ",&Dumper($peg,$seq,$full_seq);
		splice(@$ali,$tupleI,1);
	close(COORDS);
    if (@deleted > 0)
	open(ALI,">$dir/full.ali") || die "could not update $dir/full.ali";
	&gjoseqlib::print_alignment_as_fasta(\*ALI,$ali);
	close(ALI);
	if ($core_ali && (@$core_ali > 1) && open(ALI,">$dir/core.ali"))
	    &gjoseqlib::print_alignment_as_fasta(\*ALI,$core_ali);
	    close(ALI);
    $ali_tree->{ali} = $ali;
    ############# we now have an up-to-date alignment ##############
    my %coords = map { $_->[0] => [$_->[1],$_->[2],$_->[3]] } @coords;
    $ali_tree->{coords} = \%coords;
    ############# we now have up-to-date coords ##############
     my $tree = "";
#    if ((! -s "$dir/tree.newick") && (@$ali > 3))
#	&FIG::run("make_neigh_joining_tree -a 2 $dir/full.ali > $dir/tree.newick");
    if ((@$ali > 3) && (-s "$dir/tree.newick"))
	$tree = &tree_utilities::parse_newick_tree(join("",`cat $dir/tree.newick`));
	if (@deleted > 0)
	    my $ids = &tree_utilities::tips_of_tree($tree);
	    if (@$ids > @$ali)
		my %good = map {$_->[0] => 1} @$ali;
		$tree    = &tree_utilities::subtree($tree,\%good);
		open(TREE,">$dir/tree.newick")
		    || die "could not update $dir/tree.newick";
		print TREE &tree_utilities::to_newick($tree),"\n";
		close(TREE);
    $ali_tree->{tree} = $tree;
    ############# we now have an up-to-date tree ##############
    bless $ali_tree,$class;
    return $ali_tree;
sub tree {
    my($self) = @_;
    if (! $self->{tree})
	my $id     = $self->{id};
	my $data   = $self->{data};
	my $dir    = $self->{dir};
	my $ali    = $self->{ali};
	    $self->{tree} = &tree_utilities::parse_newick_tree(join("",`cat $dir/tree.newick`));
    return $self->{tree};
sub id {
    my($self) = @_;
    return $self->{id};
sub ali {
    my($self) = @_;
    return $self->{ali};
sub pegs_in_alignment {
    my($self) = @_;
    return $self->{coords};
sub functions_in {
    my($self) = @_;
    my $fig    = $self->{fig};
    my($pegH,$peg,%funcs);
    $pegH = $self->{coords};
    foreach $peg (keys(%$pegH))
	my $func = $fig->function_of($peg);
	$funcs{$func}++;
    return map { [$funcs{$_},$_] } sort { $funcs{$b} <=> $funcs{$a} } keys(%funcs);
sub display {
    my($self) = @_;
    my @lines = ();
    foreach my $tuple (@$ali)
	push(@lines,sprintf("%32s",$tuple->[0]) . "\t" . $tuple->[2] . "\n");
    return join("",@lines);
sub indel_ratio {
    my($self) = @_;
    my $seq = join("",map { $_->[2] } @{$self->{ali}});
    my $tot = length($seq);
    my $indels = ($seq =~ tr/-//);
    my $inrat = sprintf "%.3f", $indels/$tot;
    return $inrat;
sub overlaps {
    my($self) = @_;
    my $coords = $self->{coords};
    my @pegs   = keys(%$coords);
    my $ali_trees = new AliTrees($fig,$data);
    my $overlaps = {};
    my($peg,@poss,$ali2,$id2,$coords2,%seen,@overlap);
    my($peg1,$c1,$c2,$b1,$e1,$b2,$e2,$ln1,$ln2,$ov);
    foreach $peg (@pegs)
	@poss   = $ali_trees->alignments_containing_peg($peg);
	foreach $id2 (@poss)
	    if (($id2 ne $id) && (! $seen{$id2}))
		$ali2 = new AliTree($id2,$fig,$data);
		$coords2 = $ali2->coords_of;
		@overlap = ();
		foreach $peg1 (@pegs)
		    if (($c1 = $coords->{$peg1}) && ($c2 = $coords2->{$peg1}))
			($b1,$e1) = @$c1;
			($b2,$e2) = @$c2;
			$ln1 = ($e1-$b1)+1;
			$ln2 = ($e2-$b2)+1;
			$ov = &FIG::min($e1,$e2) - &FIG::max($b1,$b2);
			if (($ov > (0.9 * $ln1)) && ($ov > (0.9 * $ln2)))
			    push(@overlap,[$peg1,$b1,$e1,$b2,$e2]);
		if (@overlap > 0)
		    $overlaps->{$id2} = [sort { &FIG::by_fig_id($a,$b) } @overlap];
		$seen {$id2} = 1;
    return $overlaps;
sub coords_of {
    my($self,$peg) = @_;
    return $peg ? $self->{coords}->{$peg} : $self->{coords};
sub sz {
    my($self) = @_;
    my $n = @{$self->{ali}};
    return $n;
sub html {
    my($self) = @_;
    my $dir    = "$data/$id";
    if ((! -s "$dir/full.html") && (-s "$dir/full.ali"))
	&FIG::run("alignment_to_html < $dir/full.ali > $dir/full.html");
    return (-s "$dir/full.html") ? join("",`cat $dir/full.html`) : undef;
sub phob_dir {
    my($self) = @_;
    if (! -d "$dir/PHOB")
	if ($self->make_phob_dir("$dir/PHOB"))
	    return "$dir/PHOB";
	else
	    return "";
    else
	return "$dir/PHOB";
sub make_phob_dir {
    my($self,$dir) = @_;
    if (-d $dir)
	print STDERR "Attempt to make $dir failed: it already exists\n";
	return 0;
    &FIG::verify_dir($dir);
    my($ali,$tree);
    if (($ali = $self->ali) && ($tree = $self->tree))
	my($n,$to,$id,$seq,$idN,$tuple);
	open(IDS,">$dir/ids")       || die "could not open $dir/ids";
	open(ALI,">$dir/aln.fasta") || die "could not open $dir/aln.fasta";
	open(TREE,">$dir/tree.dnd") || die "could not open $dir/tree.dnd";
	$n = 1;
	$to = {};
	foreach $tuple (@$ali)
	    ($id,undef,$seq) = @$tuple;
	    $idN = "id$n";
	    $n++;
	    print IDS "$idN\t$id\n";
	    $to->{$id} = $idN;
	    $seq =~ s/\s//gs;
	    $seq =~ s/[uU]/x/g;
	    &FIG::display_id_and_seq($idN,\$seq,\*ALI);
	&tree_utilities::relabel_nodes($tree,$to);
	close(IDS);
	close(ALI);
	close(TREE);
	return 1;
    else
	return 0;
1;
