[Bio] / FigKernelPackages / AliTree.pm Repository:
Log of /FigKernelPackages/AliTree.pm
Sat Sep 15 22:33:31 2007 UTC (12 years, 8 months ago) by overbeek
FIGfams are now broadened to include PEGs with mismatching functions
Mon Aug 27 18:27:33 2007 UTC (12 years, 9 months ago) by overbeek
Changes since 1.3: +14 -0 lines
add strip comments argument on function_of
Wed Aug 8 18:43:37 2007 UTC (12 years, 9 months ago) by overbeek
Changes since 1.2: +3 -2 lines
strip comments when collapsing trees
Sun Jul 15 04:08:16 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.1: +65 -1 lines
allow acces to alignment library from protein page
Thu Jul 12 17:52:56 2007 UTC (12 years, 10 months ago) by overbeek
Diff to selected 1.5
add AliTrees.pm and AliTree.pm - support for alignment library
