[Bio] / FigKernelPackages / AT.pm Repository:
Log of /FigKernelPackages/AT.pm
Sat Nov 27 00:26:38 2010 UTC (9 years ago) by fangfang
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, rast_rel_2010_1206, rast_rel_2011_0119
always return psiblast search history
Wed Nov 17 16:58:29 2010 UTC (9 years ago) by fangfang
Changes since 1.3: +7 -0 lines
add make_tree
Thu Nov 11 07:40:37 2010 UTC (9 years, 1 month ago) by fangfang
Changes since 1.2: +7 -0 lines
new function: psiblast_search
Wed Nov 10 16:55:24 2010 UTC (9 years, 1 month ago) by fangfang
Changes since 1.1: +13 -16 lines
Simplified code.
Wed Oct 27 16:21:57 2010 UTC (9 years, 1 month ago) by fangfang
Initial import of Alignment and Tree module
