[Bio] / FigKernelPackages / AT.pm Repository:
Log of /FigKernelPackages/AT.pm
Links to rast_rel_2011_0928: (view) (download) (as text) (annotate)
Mon Mar 7 16:23:24 2011 UTC (9 years, 2 months ago) by fangfang
CVS Tags: HEAD, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.5: +7 -0 lines
add blast function
Sat Nov 27 00:26:38 2010 UTC (9 years, 6 months ago) by fangfang
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, rast_rel_2010_1206, rast_rel_2011_0119
always return psiblast search history
Wed Nov 17 16:58:29 2010 UTC (9 years, 6 months ago) by fangfang
Changes since 1.3: +7 -0 lines
add make_tree
Thu Nov 11 07:40:37 2010 UTC (9 years, 6 months ago) by fangfang
Changes since 1.2: +7 -0 lines
new function: psiblast_search
Wed Nov 10 16:55:24 2010 UTC (9 years, 6 months ago) by fangfang
Changes since 1.1: +13 -16 lines
Simplified code.
Wed Oct 27 16:21:57 2010 UTC (9 years, 7 months ago) by fangfang
Initial import of Alignment and Tree module
