[Bio] / FigKernelPackages / ANNOserver.pm Repository:
Log of /FigKernelPackages/ANNOserver.pm
Tue Nov 23 20:12:08 2010 UTC (9 years ago) by parrello
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.19: +2 -2 lines
Diff to previous 1.19
Fixed a POD error.
Mon Aug 23 17:24:25 2010 UTC (9 years, 3 months ago) by parrello
Changes since 1.18: +11 -12 lines
Diff to previous 1.18
Various POD fixes.
Mon Aug 9 13:46:06 2010 UTC (9 years, 4 months ago) by parrello
Changes since 1.17: +2 -2 lines
Diff to previous 1.17
Allow alternate forms of parameters to client-side modules.
Thu Jul 29 17:35:51 2010 UTC (9 years, 4 months ago) by parrello
Diff to previous 1.16
Added support for using SAS_SERVER environment variable to configure the appropriate server.
Sat Mar 27 15:19:11 2010 UTC (9 years, 8 months ago) by parrello
CVS Tags: rast_rel_2010_0526
Changes since 1.15: +3 -1 lines
Fixed a POD error.
Thu Mar 25 16:05:50 2010 UTC (9 years, 8 months ago) by parrello
Changes since 1.14: +153 -34 lines
Updates for glimmer training and special-protein finder.
Wed Feb 17 16:31:40 2010 UTC (9 years, 9 months ago) by parrello
Changes since 1.13: +5 -7 lines
Updated  the POD.
Wed Feb 10 18:07:03 2010 UTC (9 years, 10 months ago) by parrello
Changes since 1.12: +4 -1 lines
Wed Feb 10 17:25:38 2010 UTC (9 years, 10 months ago) by parrello
Changes since 1.11: +6 -3 lines
Updated the documentation for metabolic_reconstruction.
Tue Jan 19 19:51:13 2010 UTC (9 years, 10 months ago) by disz
CVS Tags: rast_rel_2010_0118
Changes since 1.10: +4 -1 lines
Fixed doc for assign_using_prot
Tue Dec 22 21:32:24 2009 UTC (9 years, 11 months ago) by olson
Changes since 1.9: +12 -8 lines
more doc updates
Tue Dec 22 20:12:19 2009 UTC (9 years, 11 months ago) by olson
Changes since 1.8: +27 -6 lines
doc changes
Wed Dec 16 20:18:07 2009 UTC (9 years, 11 months ago) by parrello
Changes since 1.7: +5 -5 lines
Fixed documentation of metabolic reconstruction.
Wed Dec 16 20:00:23 2009 UTC (9 years, 11 months ago) by overbeek
Changes since 1.6: +50 -25 lines
minor changes to documentation
Mon Dec 14 18:09:02 2009 UTC (9 years, 11 months ago) by olson
Changes since 1.5: +13 -4 lines
tweak doc on -input
Mon Dec 14 18:00:20 2009 UTC (9 years, 11 months ago) by olson
add valid kmer size range for dna
Fri Dec 11 20:44:42 2009 UTC (10 years ago) by olson
Changes since 1.3: +55 -12 lines
Make this a ClientThing subclass for the stuff that is in ANNO.pm. The locally defined methods
will execute as usual.
Thu Dec 10 19:32:29 2009 UTC (10 years ago) by olson
Changes since 1.2: +37 -26 lines
mods for new server stuff
Mon Dec 7 22:41:55 2009 UTC (10 years ago) by olson
Changes since 1.1: +14 -6 lines
fix up some pod stuff
Mon Dec 7 22:34:39 2009 UTC (10 years ago) by olson
New annotation server support.
