[Bio] / FigKernelPackages / ANNO.pm Repository:
Log of /FigKernelPackages/ANNO.pm
Wed Feb 23 21:45:52 2011 UTC (8 years, 11 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.8: +2 -2 lines
Fixed missing method problem.
Thu Oct 28 19:12:11 2010 UTC (9 years, 2 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.7: +3 -0 lines
kmer info changes
Thu Sep 30 17:10:49 2010 UTC (9 years, 3 months ago) by parrello
Changes since 1.6: +33 -3 lines
Updated to return role and OTU index from dna_small method.
Wed Aug 25 15:49:01 2010 UTC (9 years, 5 months ago) by parrello
Changes since 1.5: +103 -0 lines
Added support for small DNA function service.
Fri May 21 16:08:22 2010 UTC (9 years, 8 months ago) by parrello
Fixed metabolic reconstruction to restrict to usable subsytems.
Thu Mar 25 16:05:50 2010 UTC (9 years, 10 months ago) by parrello
CVS Tags: rast_rel_2010_0526
Changes since 1.3: +28 -0 lines
Updates for glimmer training and special-protein finder.
Fri Jan 15 12:54:57 2010 UTC (10 years ago) by parrello
CVS Tags: rast_rel_2010_0118
Changes since 1.2: +8 -6 lines
Fixed an obscure metabolic reconstruction problem.
Wed Dec 16 20:18:07 2009 UTC (10 years, 1 month ago) by parrello
Fixed documentation of metabolic reconstruction.
Fri Dec 11 20:45:13 2009 UTC (10 years, 1 month ago) by olson
new home for plain old methods to be invoked for the anno server. move metabolic reconstruction here.
