[Bio] / FigKernelPackages / ALITRE.pm Repository:
Log of /FigKernelPackages/ALITRE.pm
Sun Oct 7 00:02:32 2012 UTC (7 years, 7 months ago) by fangfang
Changes since 1.5: +96 -2 lines
add server side implementation of
  alignments_metadata_by_md5() and
Sat Oct 6 21:27:54 2012 UTC (7 years, 7 months ago) by fangfang
Changes since 1.4: +54 -0 lines
add md5_alignment_metadata()
Tue Sep 13 20:37:24 2011 UTC (8 years, 8 months ago) by parrello
CVS Tags: mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928
Changes since 1.3: +528 -288 lines
Added get_projections.
Thu May 26 21:31:26 2011 UTC (9 years ago) by parrello
CVS Tags: mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_rel40
Changes since 1.2: +913 -116 lines
Finished adding methods from AlignsAndTrees
Wed Apr 20 20:17:54 2011 UTC (9 years, 1 month ago) by parrello
CVS Tags: mgrast_dev_05262011
Uncommented metadata call.
Fri Apr 1 20:45:58 2011 UTC (9 years, 1 month ago) by parrello
CVS Tags: mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0_3, mgrast_release_3_0_4
New alignment/tree server stuff.
