[Bio] / FigKernelPackages / ACHserver.pm Repository:
Log of /FigKernelPackages/ACHserver.pm
Thu Dec 17 20:48:21 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.15: +0 -3 lines
Diff to previous 1.15 , to selected 1.12
Removed from the SAS distribution.
Tue Dec 1 23:43:22 2009 UTC (10 years, 4 months ago) by parrello
Diff to previous 1.14 , to selected 1.12
Changed to use the default URL if an empty string is specified, for compatibility with some of the scripts.
Tue Dec 1 20:57:02 2009 UTC (10 years, 4 months ago) by olson
Diff to previous 1.13 , to selected 1.12
The scripts are calling these with "url => ''" which makes them not pick up the default URL.
Mon Nov 30 11:45:22 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.12: +5 -248 lines
Converted to use ClientThing.
Revision 1.12 - (view) (download) (as text) (annotate) - [selected]
Wed Nov 25 21:58:39 2009 UTC (10 years, 4 months ago) by parrello
Fixed missing use.
Wed Nov 25 21:22:22 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.10: +7 -4 lines
Diff to previous 1.10 , to selected 1.12
Updated error handling
Wed Nov 25 20:09:40 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.9: +40 -8 lines
Diff to previous 1.9 , to selected 1.12
Add retry logic
Fri Nov 6 22:50:34 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.8: +1 -0 lines
Diff to previous 1.8 , to selected 1.12
add timeout fix
Thu Nov 5 20:55:26 2009 UTC (10 years, 4 months ago) by parrello
Diff to previous 1.7 , to selected 1.12
Restored missing URL.
Tue Nov 3 21:20:07 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.6: +145 -48 lines
Diff to previous 1.6 , to selected 1.12
Error handling restructure.
Wed Sep 30 15:33:23 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.5: +156 -67 lines
Diff to previous 1.5 , to selected 1.12
Converted to new technology.
Tue Jun 30 19:02:29 2009 UTC (10 years, 9 months ago) by disz
Changes since 1.4: +26 -1 lines
Diff to previous 1.4 , to selected 1.12
FIxed bad run_query
Fri Jun 19 17:30:02 2009 UTC (10 years, 9 months ago) by olson
Diff to previous 1.3 , to selected 1.12
server fixes
Mon May 18 17:00:00 2009 UTC (10 years, 10 months ago) by olson
CVS Tags: rast_rel_2009_05_18
Changes since 1.2: +12 -3 lines
Diff to previous 1.2 , to selected 1.12
mods for production ACH server
Wed May 13 20:03:06 2009 UTC (10 years, 10 months ago) by disz
Diff to previous 1.1 , to selected 1.12
Sapling based server
Mon May 11 19:06:39 2009 UTC (10 years, 10 months ago) by disz
Diff to selected 1.12
Client side package to access the ACH server
