[Bio] / FigKernelPackages / ACHserver.pm Repository:
Log of /FigKernelPackages/ACHserver.pm
Thu Dec 17 20:48:21 2009 UTC (10 years, 1 month ago) by parrello
Changes since 1.15: +0 -3 lines
Diff to previous 1.15 , to selected 1.7
Removed from the SAS distribution.
Tue Dec 1 23:43:22 2009 UTC (10 years, 1 month ago) by parrello
Diff to previous 1.14 , to selected 1.7
Changed to use the default URL if an empty string is specified, for compatibility with some of the scripts.
Tue Dec 1 20:57:02 2009 UTC (10 years, 1 month ago) by olson
Diff to previous 1.13 , to selected 1.7
The scripts are calling these with "url => ''" which makes them not pick up the default URL.
Mon Nov 30 11:45:22 2009 UTC (10 years, 1 month ago) by parrello
Changes since 1.12: +5 -248 lines
Diff to previous 1.12 , to selected 1.7
Converted to use ClientThing.
Wed Nov 25 21:58:39 2009 UTC (10 years, 2 months ago) by parrello
Diff to previous 1.11 , to selected 1.7
Fixed missing use.
Wed Nov 25 21:22:22 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.10: +7 -4 lines
Diff to previous 1.10 , to selected 1.7
Updated error handling
Wed Nov 25 20:09:40 2009 UTC (10 years, 2 months ago) by olson
Changes since 1.9: +40 -8 lines
Diff to previous 1.9 , to selected 1.7
Add retry logic
Fri Nov 6 22:50:34 2009 UTC (10 years, 2 months ago) by olson
Changes since 1.8: +1 -0 lines
Diff to previous 1.8 , to selected 1.7
add timeout fix
Thu Nov 5 20:55:26 2009 UTC (10 years, 2 months ago) by parrello
Restored missing URL.
Revision 1.7 - (view) (download) (as text) (annotate) - [selected]
Tue Nov 3 21:20:07 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.6: +145 -48 lines
Error handling restructure.
Wed Sep 30 15:33:23 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.5: +156 -67 lines
Converted to new technology.
Tue Jun 30 19:02:29 2009 UTC (10 years, 7 months ago) by disz
Changes since 1.4: +26 -1 lines
FIxed bad run_query
Fri Jun 19 17:30:02 2009 UTC (10 years, 7 months ago) by olson
server fixes
Mon May 18 17:00:00 2009 UTC (10 years, 8 months ago) by olson
CVS Tags: rast_rel_2009_05_18
Changes since 1.2: +12 -3 lines
mods for production ACH server
Wed May 13 20:03:06 2009 UTC (10 years, 8 months ago) by disz
Sapling based server
Mon May 11 19:06:39 2009 UTC (10 years, 8 months ago) by disz
Diff to selected 1.7
Client side package to access the ACH server
