[Bio] / FigKernelPackages / 5S_rRNA_reps.pm Repository:
Log of /FigKernelPackages/5S_rRNA_reps.pm
Revision 1.2
Mon Nov 4 16:51:47 2013 UTC (6 years, 6 months ago) by golsen
CVS Tags: HEAD
FILE REMOVED
This package was unusable due to starting the file name with a digit.
It is functionally replaced by RNA_reps_5S_rRNA.pm
Sat Jan 7 00:30:01 2012 UTC (8 years, 4 months ago) by golsen
CVS Tags: mgrast_version_3_2
A set of 5S rRNA sequences.
