[Bio] / FigCommon / tool_hdr_py.pl Repository:
View of /FigCommon/tool_hdr_py.pl
Revision 1.2 - (download) (as text) (annotate)
Mon Dec 5 19:10:06 2005 UTC (14 years, 7 months ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, help, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Added license words.
# Public License.
# Create a new fig script.
open(FH, "<$FIG_Config::fig_disk/config/fig-user-env.sh");
while (<FH>)
    chomp;
    if (/^RTARCH=\"(.*)\"/)
	$arch = $1;
	last;
if (!$arch)
    die "Couldn't determine FIG architecture name\n";
$file = "$FIG_Config::fig_disk/dist/releases/current/$arch/tool_hdr_py";
open(FH, "<$file") or die "Cannot open tool_hdr_py file $file: $!\n";
if (@ARGV == 0)
    while (<FH>)
	print;
    close(FH);
else
    $out = $ARGV[0];
    open(OUT, ">$out") or die "Cannot open output $out: $!\n";
    while (<FH>)
	print OUT $_;
    close(FH);
    close(OUT);
    system("chmod +x $out");
