[Bio] / FigCommon / switch_to_release.pl Repository:
Log of /FigCommon/switch_to_release.pl
Mon Dec 5 19:10:06 2005 UTC (14 years, 1 month ago) by olson
Changes since 1.10: +17 -0 lines
Diff to previous 1.10 , to selected 1.5
Added license words.
Wed Jun 29 19:46:49 2005 UTC (14 years, 6 months ago) by olson
CVS Tags: caBIG-00-00-00, lwc, merge-trunktag-bodev_news-3
Changes since 1.9: +1 -0 lines
Diff to previous 1.9 , to selected 1.5
catchign up
Tue May 17 16:22:03 2005 UTC (14 years, 8 months ago) by olson
Diff to previous 1.8 , to selected 1.5
RTConfig support.
Tue Jan 6 22:32:54 2004 UTC (16 years ago) by olson
Diff to previous 1.7 , to selected 1.5
bugfix on invocation of SwitchRelease module
Tue Dec 23 16:10:48 2003 UTC (16 years, 1 month ago) by olson
Changes since 1.6: +12 -46 lines
More configure setup.
Fri Dec 19 20:59:20 2003 UTC (16 years, 1 month ago) by efrank
fix rt thingie
Fri Dec 19 20:56:03 2003 UTC (16 years, 1 month ago) by efrank
add chmod
Fri Dec 19 20:06:27 2003 UTC (16 years, 1 month ago) by efrank
bugfix
Fri Dec 19 20:04:03 2003 UTC (16 years, 1 month ago) by efrank
add make stuff
Fri Dec 19 20:03:39 2003 UTC (16 years, 1 month ago) by efrank
add make stuff
Fri Dec 19 17:25:40 2003 UTC (16 years, 1 month ago) by efrank
Diff to selected 1.5
Switch to release script
