[Bio] / FigCommon / switch_to_release.pl Repository:
View of /FigCommon/switch_to_release.pl
Revision 1.7 - (download) (as text) (annotate)
Tue Dec 23 16:10:48 2003 UTC (15 years, 11 months ago) by olson
Changes since 1.6: +12 -46 lines
More configure setup.
use FIG;
# switch_to_release <release_number>
# Change the currently-running release to <release_number>
# Check to be sure that $fig_disk/dist/releases/<release_number> exists
# Update $fig_disk/CURRENT_RELEASE with the new release number.
# Swing the symlinks $fig_disk/FIG/bin and $fig_disk/FIG/CGI to the right place
# Create the symlink $fig_disk/disk/releases/current to point to <release_number>
# Expand the environment-specific tool headers from $fig_disk/config/base_tool_hdr
# to include the release-specific directories. Place the output in
# dist/releases/<release_number>/<arch>.
require SwitchRelease;
if (@ARGV != 1)
    die "Usage: switch_to_release release-number";
my $release_number = $ARGV[0];
# We assume the architecture name is keept in $RTARCH in the environment.
my $arch = $ENV{RTARCH};
SwitchRelease::switch_to_release($FIG_Config::fig_disk, $arch, $release_number);
