[Bio] / FigCommon / switch_to_release.pl Repository:
View of /FigCommon/switch_to_release.pl
Revision 1.10 - (download) (as text) (annotate)
Wed Jun 29 19:46:49 2005 UTC (14 years, 8 months ago) by olson
CVS Tags: lwc, caBIG-00-00-00, merge-trunktag-bodev_news-3
Changes since 1.9: +1 -0 lines
catchign up
use FIG;
# switch_to_release <release_number>
# Change the currently-running release to <release_number>
# Check to be sure that $fig_disk/dist/releases/<release_number> exists
# Update $fig_disk/CURRENT_RELEASE with the new release number.
# Swing the symlinks $fig_disk/FIG/bin and $fig_disk/FIG/CGI to the right place
# Create the symlink $fig_disk/dist/releases/current to point to <release_number>
# Create a symlink $fig_disk/dist/releases/last to point to the pre-switch release.
# Expand the environment-specific tool headers from $fig_disk/config/base_tool_hdr
# to include the release-specific directories. Place the output in
# dist/releases/<release_number>/<arch>.
require FigCommon::SwitchRelease;
if (@ARGV != 1)
    die "Usage: switch_to_release release-number";
my $release_number = $ARGV[0];
# We assume the architecture name is keept in $RTARCH in the environment.
my $arch = $ENV{RTARCH};
FigCommon::SwitchRelease::switch_to_release($FIG_Config::fig_disk, $arch, $release_number);
exit 0;
